Wavefront : 35165.5
Started by darkspeed, January 06, 2010, 01:15:22 AM
darkspeed
Where i said
" 35165.5 HZ is the transition point where the wavefront changes direction "
I meant to say
" 35156.5 HZ is the transition point where the wavefront changes direction "
And NO my monitor is not set to 35156.5 HZ horizontal frequency  ;D
EMdevices
very nice construction darkspeed,  I like it.
I noticed you mentioned using a resistor in an output tank circuit (not shown) to preserve the Q of the tank,  I would suggest an inductor, as it is not lossy, and at the frequency you're working with, it will have a high impedance.  That's the standard approach used by many. ( because we need impedance matching to transfer the most power)
Now imagine your HV coil  (gold colored) was not hooked up to a signal generator, but instead had a capacitor across it's leads to form a tank circuit that is resonant at a particular magnetic frequency  that is external to your lab,  like power line harmonics, WiFi signal, AM radio station, etc..    This is my approach to the Steven Mark TPU replication effort.  Think about it, but don't abandon your line of research.  ( we have to diversify our research to cover more ground )
EM
wattsup
Yep, damn nice.
Looks like a Tesla coil primary bottom, into the secondary high voltage middle and back to another primary top, compress, expand, compress. Plus that top litz toroid. Lots of possibilities there to play with.
darkspeed
Thanks guys.
Yes EM in the photos it is in tune mode, you are correct there is a cap that goes across L2 to tank it.
The strange thing is 35156.5 HZ is a well known horizontal frequency of displays set to 800x600 and when i tank to around 35k I get a voltage rise between 35156 and 35157. I am nowhere near any other building and when i shut everything (at the buildings main breaker) down in the lab and scope i with an old analog scope, the voltage rise is still there.
I was talking to Grumpy about the possibility I was receiving 8v of power from someones monitor from a distance. There is a lot to play with is correct!
Im not trying to wind a TPU.. Im just looking for clues to the puzzel
Bruce_TPU
Hi Darkspeed,
You are on ONE of the right frequencies I give in the last two pages of my thread.  You need a 15" coil, and add the two modulation freqs with it, the 115 and 222khz, mix them and shoot them in as a standing wave to intermodulate...
You are on the right track...kind of...LOL
Cheers,
Bruce
