Solid State Orbo System
Groundloop
Bruce,
I read the link you posted. I agree that "We must be much more "technical", about this."
but the more technical I go, the more money it costs me. The resent materials I just
bought for the double solid state did cost me over 3500 Norwegian Kroner. (700USD)
And I still need to buy some plastic sheets to build the coil formers, glue etc. So this
"free energy" research is far from free. :-)
Alex.
Bruce_TPU
Quote from: Groundloop on January 14, 2010, 01:00:11 AM
Bruce,
Alex.
Hi Alex,
The Metglas cores are only about 2 to 3 USD each.  I happen to own 6 Brooks coils, that I had professionaly made.  I would be willing to ship you 2 (loaners, for they were VERY expensive...LOL) to test with as the generator output coils.  Simply PM me your mailing address and I will ship them UPS.  I will pay for the shipping.
Do you have a gauss meter?  This would also seem to be a much needed piece of equipment., and I need one myself.  Slowly, piece by piece we can put together what we need.   :)
Cheers,
Bruce
0c
Quote from: Groundloop on January 13, 2010, 11:57:40 PM
Oc,
I have not tried garden wire. I will let the Tom Bearden MEG rest for now.
I spent almost three months testing that unit back in 2007. I did build
the MEG from patent information but did not get it to work. Maybe I will
try more testing on the MEG one day but not right now. I have had more success
with the toroid shielding and I think that can be implemented into this MEG.
A.
Sorry Groundloop,
I didn't make myself very clear. I was referring to the MEG only to illustrate the coil-within-a-coil concept. But my suggestion was related to the Solid State Orbo. The coil of garden wire would give you a high permeability core that can be saturated but would also generate electricity as the toroidal coil of copper surrounding it is pulsed. It would be a lot smaller than that MEG coil.
This way, your generator coil is built into the core of your SS Orbo. Just add magnets and a battery.
0c
Groundloop
Bruce,
Thank you for your kind offer to loan me two maximum inductance with a given length of
wire coils. I starting to go into a mild information overload right now and need to focus
on the actual build of my two field solid state. I see no need to use your coils right
now, but will consider your offer at a later stage of testing. I'm sorry to say that I
do not have a Gauss meter. I did put that on my xmas list but I did not get it. :-)
@Oc,
Thank you for clarifying your thought on this matter. Insulated soft Iron wire is
probably a great method for combining a core and a coil into one compact unit.
Alex.
gotoluc
Quote from: gotoluc on January 13, 2010, 04:44:24 PM
Hi Groundloop and all,
I was wondering Alex if we could use the Flynn Parallel Path idea to do the same thing?
The first image below is the Flynn Parallel Path basic idea.
The second image I modified and added coils on each ends.
I'm quite sure you're familiar with the Flynn Parallel Path. It's claimed to make over 3 time the magnetic field strength of an electromagnet. It should work well with the H-Bridge switch to make the reversing fields for the flux gate coils and it could easily be brought to Resonance with the right Capacitor in Series.
Link to basic info: http://www.peswiki.com/index.php/Directory:Flynn_Parallel_Path_principle_device
Let me know what you think.
Luc
Hi Groundloop,
I have a new video demonstrating the Flynn Parallel Path Device for the idea I shared above.
Link to video: http://www.youtube.com/watch?v=kAO44dOC6m0
The coils and cores I used are from shaded pole motors which are used in 50 CFM Bathroom exhaust fans @ $20.ea. I though of trying these before investing too much time and money in this device.
I must say that I'm impressed with the results and we also need to keep in mind that my video is only demonstrating the flux release side when the coils are activated and not demonstrating the more then double the magnetic flux attraction power at the opposite end. I still need to add some pickup coils on each ends to see how it would work out in that configuration.
I also think this effect can make an interesting motor. Here is a video I found on YouTube of someone that has built on using the Flynn Parallel Path concept. Notice that when his motor is under load the current does not go up. I find this very interesting ;)  Isn't the Orbo doing the same thing ???
Link to video: http://www.youtube.com/watch?v=7yoM4Qjmduk
Alex, please let me know if you prefer I not post this in your topic.
Thanks
Luc
