Solid State Orbo System
rave154
 ebeautifully neat winding mags !
cant wait to see more of your inovative tests on video
Magluvin
Thanks Rave
Something I had not tried nor gave much thought til Bruce TPU was getting the core to saturate. I dont know why I hadnt tested for this before. I had seen the dropping mag tests, but didnt think much of the differences there could be. But thanks to Bruce, it has my full attn. now. Hopefully it will drop a mag when Im done.  =]  If it does, Im scared to see what the output might be.  :o
My first Orbon I used the 30ga red on the toroid coil and was getting 160v out on the green wire 150 turn pickup on the core that I had re wrapped the toroid coil to the green 26ga and only got about 30v. So now It should be grand. The pickups, as I use less turns, have less volts but higher current out. So if this thing with 18 turns only puts out 10v, the current should be massive compared to what I had before, if I reach saturation or even closer to it than previously.
Mags
Bruce_TPU
Hi Mags,
Okay, you have inspired me!  LOL  I had to wind this last night.  The first Pic is of all of my taps... I wound them with STRANDED magnet wire... I think it will make a differance.  Also, I have three taps.  Second pic is with 26 awg magnet wire wound over top.  I am going to try this before winding some more layers.  Home computer has BAD virus, so will post as I can...
Cheers,
Bruce
http://energyfreedomreport.com
Magluvin
This is weird. I now have good magnet drop, but nill on output. I have to check my board. I dont believe I have changed anything doing tests on other stuff.
Do ya think that maybe the 30ga and so many wraps is affecting my output on the pickup? Maybe I have to change the timing cap for lower freq.
I have been up since yesterday, and i was all eager to do this today. Maybe Im just tired and dont know what Im doing. lol
Man I spent a long time working on this winding to get the most so everything would fit well.
My other 2, yellow and green beads wouldnt drop a mag at 12v. It would shudder, but no drop. This one dropped at 5v and thats (5v) what I have been running on all my stuff ive been testing lately with the sig gen since I made it.
I can hear the freq from the coil, louder than I have heard from the others. I was even able to hear the Agentgates coil, except for stuff over 15khz. The coils are not good tweeters. =]
My pickup is only 18 turns but i should get something, 2v, whatever. Maybe Im dreaming.  :-\
Im going to take a lil break and check things out after a bit. Ive been at it since this morning.
Mags in Didney Lan
rave154
MAG, enjoy the rest, it'l do ya good and im sure once youve gone over the circuit with a fresh brain & a fine toothcomb youll figure it out
Kudos for your efforts ( dont even ASK what im doing with my rodin coil lol ! )
