Solid State Orbo System
Bruce_TPU
Afternoon ALL,
As I continue my methodical build of my SSG1 Solid State Generator v.1.  My bars are filed and sanded.  Toroid is picked up at the Post Office on Monday and now I work on an improved circuit for my Steorn Magnet Motor.
@ Alex
If you would like me to make you a toroid using my unusual ingredients, I gladly will, if you would like to test it and post the results.  My treat!  Just tell me the size that you would like, or a bar or both.
Cheers,
Bruce
http://www.energyfreedomreport.com
Omega_0
Quote from: Bruce_TPU on February 21, 2010, 02:51:15 PM
Afternoon ALL,
If you don't mind, I'd like to suggest some modifications.
The air gap should be on the core side (both top and bottom), and it is necessary. Without it you will find that the core will never "disappear" completely or it will consume a lot of current. You can also make the gap variable, because there will be a tradeoff, which you can find only by experimenting.
I don't see any need of air gap on the pickup side. You want all flux to flow into the pickup for max output. I wonder why you put it there.
Edit: Now I see the need of this gap. See below posts.
Second, the core should be completely wound. This will reduce input current, and as the core must not touch the poles, there is no point leaving that space without copper.
All the best, and keep posting those vids. :)
Omega_0
One more.
This will double the reluctance for same amount of current.
gyulasun
Quote from: Omega_0 on February 21, 2010, 03:35:43 PM
Hi,
I think you have to use some air gap at the pickup side too, and it also needs experimentation how big gap is optimal.  I say this because with no gap at all at the pickup side, the flux from the permanent magnet will always prefer staying towards the pickup side and not readily change towards the toroid side, just because the reluctances strongly differ.
Just try the setup, close the magnetic path on the pickup coil side as shown by you and THEN try to close the path on the left hand side: even with no airgap at all you will find the toroid will be hardly attracted when its coil is off and even less attracted when its coil is ON to saturate the toroid.
I say these because I recall my tests on a Flynn parallel path setup where I found a similar behavior I described (I know the differences between this setup and the parallel path setup, but those differences do not matter from flux changing path points of view).
rgds,  Gyula
gyulasun
Quote from: Omega_0 on February 21, 2010, 03:55:11 PM
One more.
Now this is a much better situation indeed, I like it! Thanks.
Gyula
