Solid State Orbo System
Bruce_TPU
Quote from: Groundloop on January 07, 2010, 01:08:34 AM
Oc,
Thanks for the added information about the Orbo motor system.
In this thread we are trying to make a solid state version. So some of your points will not apply.
But good information anyway. One factor for the solid state will be the frequency. Higher frequency
will give out more power. This is compatible to RPM in a rotor, I guess. One other factor in a solid
state system is resonance in the input toroid cores. This will lower the input usage to almost
nothing while at the same time switch the magnetic field on and off in the generator coil.
So there is a lot to research.
Alex.
EXACTLY!  Those two items alone, and the addition of the increased flux from double sets of magnets and added steel, might just do the job...  :)
Cheers,
Bruce
stprue
Ahhh
Nice to have you back on the scene Bruce!
;D
Groundloop
@Staffman,
Today I tried to measure the inductive kick back voltage spike.
I set the o-scope to 5 Volt/Div and used the probe at X10.
So each Div. on the vertical on o-scope is 50 Volt. The inductive
voltage spikes was above the o-scope edge. The setting on
the switch was NOT at maximum. I can go even higher.
So the inductive kick back voltage spike is > 50 *10 = 500 Volt. I estimate
closer to 1000 Volt or more when the switch is at maximum setting.
This is the reason that I'm using a 1500 Volt transistor.
Alex.
Staffman
Wow groundloop! That's one heck of a spike! The IRF PF50 should be here in a few days. Should I worry about frying it?
Groundloop
@Staffman,
It will probably survive. It depends on several factors. One is
you input voltage. Two are the toroid coils. Three is how much
power you put into your toroid. So if you don't push the RA
switch to maximum then you should be safe. Your transistor
is rated 900 volt so you can push a lot of power into the
toroid before the transistor blows up.
Alex.
