Solid State Orbo System
Bruce_TPU
Hello ALL,
Well, I did decide to do a few more experiments, using another old barely alive battery.  I tried to use an aluminum insert into the toroid hole, as a heat sink.  My thinking was that it would either heat things up in there, or cool them off a bit more...  ;)
I would caution everyone not to get too excited, as I will not really be convinced my self, until I use the laser thermometer.  If it says yes, then I can think of some brand new applications.
As the rotor speed slows, and the switching speed slows, the temperature gradually rises.
Cheers,
Bruce
gravityblock
I moved this post to the other thread, since it wasn't directly related to a solid state device.  It's about an experiment done by E. Rutherford in the late 1800's on magnetic viscosity.  Its probably best for any discussion of this article to be in the other thread.
GB
gravityblock
Quote from: exnihiloest on March 08, 2010, 01:40:33 PM
You said:
"A few others here have also reported a cooling effect from their replications."
If it is not related to Orbo, I suggest you speak elsewhere about the Amdam's motor. It is not the goal of this thread. Thanks.
The link I posted to the Adams theory also has extensive information on solid state devices based around this thread.  You obviously didn't look at the link, if you did then you would know this.  There are similarities and both have the same basic principals, so there is some useful information in the reference link I provide that is related to the ssOrbo (especially if Bruce has noticed a cooling effect in his SS device because this has been reported in the Adams replications also).
If my memory serves me correctly, I believe Steorn has said the coils in the Orbo doesn't necessarily have to be a toroid in order to have the effect.  The toroid is used to eliminate or reduce the BEMF/CEMF to near 0, but the shape of the toroid itself doesn't produce the effect.  If this is the case, then it would make it even more like the concept based around Adams.  There is no reason in having a discussion about how relevant my post is to this thread, for it will only lead to another distraction.
GB
exnihiloest
Quote from: void109 on March 08, 2010, 01:53:23 PM
The cooling has been shown present in Orbo replications.  And the effect looks to be present in the SS Orbo replication by Bruce_TPU.  Understanding what we're observing is important, no?
Hi void109
I knew the magneto caloric effect. What I asked first was "where can we find measurements about a cooling effect in Orbo system?".
"Observing" without measurements in not convincing, question of faith.
The cooling effect when the field is removed is a priori canceled by the heating effect when the field is built. I don't observe cooling in my own experiments. It is the reason of my question.
gravityblock
Quote from: exnihiloest on March 09, 2010, 03:27:04 AM
Hi void109
http://www.overunity.com/index.php?topic=8528.0
GB
