Solid State Orbo System
exnihiloest
Quote from: freeorbo on March 19, 2010, 11:20:58 PM
Any version of the 2sGen is "over unity," because all of the energy going through the toroid can be accounted for, but none of the energy coming out of the pickup coil can be.
False assertion. When a part of the ferrite core is saturated, there are strong flux leakages every where around. When current is drawn from a pickup coil coupled to this change of flux, energy is provided by the source of the change of flux, which is the current in the toroid coil.
wattsup
Quote from: Bruce_TPU on March 19, 2010, 01:12:04 PM
Experimental Note:
I forgot to mention last night, that when the Aluminum was added, there is tremendous vibration now of the SSG3, when running on 12v.
I always believed that SM wrapped the collectors in Aluminum wires as the control wires on the TPU, for many reasons, including the fact that when asked if the control wires were copper, he replied, OTHER.  I know they are not steel, and when I wrapped an exact replica of the 6" TPU, according to the given winding instructions, I used steel wire for the controls and weighed it.  Determined the weight if I had used aluminum wire and found it would have matched exactly to the engineers reports stated weight, less an ounce or two for electronics and battery.
Now, I am solidly convinced.  magnet, alum control wires, copper stranded collector, three freq's to intermodulate.  30.075 KHz 222 KHz and 115 KHz for a 15" TPU.  Sorry for getting off track here, I just thought I would mention this...
Cheers,
Bruce
@Bruce_TPU
Yes sirreeeeee. That is all part of the test list for verification of as many variables as possible.
Regarding your stacked coils, from what I have learned doing my videos, I think you may consider stacking them off center, meaning put the first one on the table, then the core of the second to go over the center of the first, then the core of the third to go on the center of the second and so on. I made a quick diagram below. I would be very curious to know if the coupling effect is increased.
Bruce_TPU
Quote from: jaculat on March 20, 2010, 11:03:42 AM
Hi all
another clip
http://www.youtube.com/watch?v=SDRJFfpFzuI
Hi Jaculat,
I liked your video, just a quick couple of questions for you.  In your little write up on youtube, you say, "I've noticed that at higher freq current drops more than 10 times."
Are you talking about input current into your toroids?  Not output current to your LED's correct?
At what frequency did you see the ten time drop in current?
And lastly, could you post your 555 circuit and your input circuit pls.
Sorry about all of the questions, but they are important to my work.
@ Wattsup
I tried that early on, and it was promising, but then I added the bias on the outside of the brooks, as well as the interior bias winding and then the steel wire core inside of that.  And without all of that, I get very little output.
Great ideas though and please keep them coming!
Cheers,
Bruce
jaculat
Bruce_TPU
I meant input current. Ne555 circuit is basic astable generator with freq and impulse regulation you can find many types everywhere... Don't know exact freq but more than 10 kHz I assume. Led works best at 1-3 kHz but current is high. I have only 1 meter so I can't measure 2 parameters at ones....
