Solid State Orbo System
Bruce_TPU
Quote from: LarryC on March 22, 2010, 05:23:55 PM
Check out the 'Velleman dc to pulse width modulator' on google. It is a complete kit and has freq adj and Pw adj. Cheap as $22.00 before shipping. I've used it for years with no problems.
Regards, Larry
Hi Larry,
That would be awesome...I just can't seem to find it...LOL  I have found Velleman scopes etc, but not as you describe.  If you would be kind enough to provide a link, I would be very grateful.
Thanks!
Bruce
EDIT:
I found this one on the Web, is it the one you refer to?
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=120539
tak22
Bruce,
It's probably the Velleman K8004 kit that Larry is mentioning. Here's a typical link for it:
http://www.apogeekits.com/pulse_width_modulator.htm
tak
Bruce_TPU
Quote from: tak22 on March 22, 2010, 08:18:41 PM
Bruce,
tak
Hi Tak,
Thanks, that is the one that I thought.
@ ALL
My only concern is that the frequency appears limited to 5KHz, otherwise it would appear to be a great buy.  I wonder if there could be a way to up that frequency range without redesigning the whole circuit?
Cheers,
Bruce
teslaalset
Bruce, I am using a small microcontroller kit as pulse generator:
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
It can be programmed in quite a simple manner using an USB cable (not included) and a PC.
Using the Arduino kit I can program it to generate up to 4 Mhz using assembler, but it can be programmed in C+ as well, although it is less efficient. Using C+ may limit the output frequency to approx 1 Mhz.
Output is 5 Vpp
Seems good enough for your experiments.
Costs: 25-28 euro.
Locations to buy: click the 'buy' link at the top of that page and it will give you the most popular sales addresses.
haithar
Yes 5V output voltage, but you should use a transistor after that! The current which mikrocontroller boards can deliver are usually in the mA range and by no way enough to run something which needs power in the Watt-range.
