Solid State Orbo System
Energy4All
From a permanent magnet motor perspective; if one were to arrange the curved magnets in the gate as described by Howard Johnson in Spintronics The Secret World of Magnets on say a rim and spaced properly with said rim freewheeling on an axlis maintained by a secondary stationary rim or non magnetic tubular design; one could conceivably have quite a generator of the ORBO type design. I believe a tube within a tube design would be most effective.
Energy4All
Upon further consideration; a half tue as the stationary track would be a preferred embodiment; with the pickup coils positioned along the perimiter of said track.
Bruce_TPU
Good Evening ALL,
I am finally home from my travels, and should be able to test my SSG3 with my new Pulser Kit, this weekend....
I am curiose of the results!   ;)
Cheers,
Bruce
synchro1
I proposed a Toroid earlier with an output wrap and a stack of Neos spanning the middle with tiny aperture flux blocker coils embedded in each side of the toroid where the magnet poles meet the inner edges, designed to alternate the polarity magnetization of the core. Each pulse would pole reverse and demagnetize the core material. The important factor though, is that with a properly programed pulse, first a simultaneous twin flux blocker pulse would allow the material to demagnetize to the point of retentivity, followed by an off of the opposite polarity from the start charge, driving the material to the point of coercivity and zero magnetization. At this point both flux blocker coils would be recharged again to allow an output delay rest cycle, where the core material would have a chance to do it's electron reorganization work. Thence it would transform heat into electricity and generate demagnetization current in the output wrap. The same coil would again discharge and drive the material to the point of opposite saturation where the twin charge would again be applied, repeating the cycle. A complex circuit program like this could optimize output from this simple design. The B-H curve should work exactly backwards here, flux density should be in direct proportion to the coil field intensity.
smoky
@Bruce_TPU
Hi Bruce I think you're onto something important with the Aluminum.
Floyd Sweets VTA was constructed with an Aluminum box around the coils.  Dr James Schwartz uses Aluminum sheet cut out around wound magnets (and Bismuth) in his ERR.
My best guess is it might introduce a flux reflection like a mirror by intercepting a rising flux.... turning it into an induced current & the resulting current flow in the Aluminum then produces it's own flux opposing the original flux.  So the polarity is identical but the direction is reversed on rising fluxes.
When the incoming flux tries to reduce the polarity reverses producing an attraction flux opposite to the original flux.
This is easily seen in the various Youtube videos where they drop a big Neo onto a Copper or Aluminum plate.  It falls in slow motion due to the incoming rising density flux.
However if the Neo is slid around close to the plate the plate tends to drag along underneath the Neo due to the falling flux.
So overall I believe there's a 90 degree phase shift in incoming to reflected flux occurs.
(When plotted one against the other, assuming the incident flux to be sinusoidal in nature).
