Solid State Orbo System
Groundloop
Bruce,
I measured the two toroid coils in series to be 0,8 DC Ohm.
The generator coil to 1,2 DC Ohm. The trigger coil to be 1 DC Ohm.
I'm really looking forward to your replication. It will be fun to compare
results and share research.
Alex.
Groundloop
@Staffman,
>>The suspense is getting unbearable
Yes, I know how you feel. LOL
Alex.
Bruce_TPU
Hi Alex,
Could you please try a 100 ohm resistor in place of the bulb on the generator coil output and tell me what the voltage is across the resistor?
Also, a scope shot of the sine wave on the output across the resistor?
Inquiring minds want to know... LOL  :)
Thank you,
Bruce
Groundloop
Bruce,
Attached images shows volt and scope with 100 Ohm 1% Metalfilm resistor over
output coil. DVM set to 20 Volt AC range.
Scope set at: Time Base = 20uSec/Div
                    CH1 Probe to 10X
                    CH1 = 0,5 Volt/Div
                    Ground at center of screen.
Alex.
Bruce_TPU
Quote from: Groundloop on January 08, 2010, 07:17:56 PM
Bruce,
                    CH1 Probe to 10X
                    CH1 = 0,5 Volt/Div
Alex.
Thank you for the test.
But shoot, that is not good news at all...  :(  I was hoping it would have read 30 volts on it or so....
So, I calculate with 2.9 volts (real)
across a 100 ohm resistor gives us .029 amps
for a total of 0.0841 watts from one generator coil.
We would need to both drastically DECREASE the input required power and figure out a way to gain more wattage from the generator coil.
With eleven coils we will have .9251 watts.  I can't recall how much power your present circuit is using.
Any ideas any members have reading this to harvest more useable power from the Generator coil would be appreciated.
One thought is to perhaps collect on the output with a capacitor (after diode) and then redo the 100 ohm test again.  I think this may work better for us...perhaps.. ;)
Cheers,
Bruce
