Global Warming Truth
Started by PaulLowrance, January 07, 2010, 12:05:36 PM
PaulLowrance
Quote from: Azorus on January 22, 2010, 09:35:21 AM
Up to the late 1970's there is a near direct correlation with solar output and the earths warming pattern.  After that there is less than a 75% correlation with solar output and less than a 78% correlation with greenhouse gases.  Thus making it inconclusive.
Sorry I'm no longer watching this thread due to spending more time on a legit excess energy magnetic design, but happened to glance at the recent posts here today. I would like to add that there is also no correlation between solar output up to 1900. See attached image. So far the only 100% direct correlation is CO2 and human population. That along with a massive amount of further data is why over 97% of active publishing climatologists believe humanity is a significant cause of Global Warming.
Azorus
PaulLowrance
Quote from: Azorus on January 22, 2010, 12:04:49 PM
for you pual
http://www.skepticalscience.com/What-does-Solar-Cycle-Length-tell-us-about-the-sun-role-in-global-warming.html
you should have read the link.  You of all people would agree with this guy.
I understand his research agrees with my conclusion, but added my post because you made no mention to the fact there's also no solar & global warming correlation prior to 1900.
Azorus
There is no correlation with greenhouse gases either.  so what warmed up the earth during that time?
ResinRat2
Quote from: PaulLowrance on January 22, 2010, 11:36:46 AM
Another recently "peer-reviewed" paper showing the conclusion that during the long Geological history of earth, there was no correlation between global temperature and atmospheric carbon dioxide levels.
http://www.friendsofscience.org/assets/files/documents/debate.pdf
So Paul is wrong; and his statement that 97% of active publishing climatologist believe humanity is a significant cause of global warming is based off of only 79 people on the whole planet. I dealt with this already starting here:
http://www.overunity.com/index.php?topic=8608.msg222865#msg222865
Paul is a deceiver, giving the impression that the over 97% is a large group of people. It is not.
The major link between water vapor and Carbon Dioxide levels in the atmosphere and global warming is shown to be that water vapor and Carbon Dioxide levels increase AFTER the average global temperature rises. This is a result of the solar activity warming the atmosphere and the solubility of Carbon Dioxide in the oceans going down due to warming. This is what is shown to raise the Carbon Dioxide and water vapor levels.
Obviously this will go on and on because Paul refuses to believe that the sun warms the atmosphere and the physics of carbon dioxide solubility shows that as the temperature rises the solubility of Carbon Dioxide gas in water decreases, thus releasing more Carbon Dioxide and water vapor into the atmosphere.
