The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
Ok Here is my thinking - A hub dynamo from shimano http://techdocs.shimano.com/media/techdocs/content/cycle/SI/HubDynamo/HB-NX22/20GED-DH-2N30-E_HB-NX22-EN_v1_m56577569830605425.pdf is rated for 6V 2.4watt. The fastest I've ever been on my mountain bike is 50kmh or 830m/minute. My wheel circumference is 205cm so my wheel would have to be doing around 4000rpm? I'm assuming the hub dynamo will reach top power before then. I can get my motor doing that at around 50mw. The current rotor has a lot more torque so I am hoping the dynamo will have a similar drag to my 12vdc motor that I had attached at 2500rpm. Just awaiting my dynamo :) May have to do some jiggery pokery to get the dynamo far enough away from the rotor mags so they don't interfere but I'm a bit excited :D
gyulasun
Hi Jim,
I was qurious to learn the efficiency of hub dynamos in general and found claimed efficiencies of about 62-65% as normal.
I try to follow your reasonings with the numbers on speed, circumference etc but I am puzzled  ::)  not good at such calculations.  I think it is not the best to start with your max speed (50km/h) because as I read most hub dynamos has a built in voltage limiter (and it is a power Zener diode with 7V or so to limit output voltage above a certain speed) so that the bulb(s) should not burn out.
So if you do not mind you could start with say 20km/h speed and calculate with it further on how the energy "budget" will look like?
I have not found any efficiency data for your hub type. In the data sheet you gave link to I see warning of electrical shock danger if you happen to touch the output wires and I am surprised if it produces much higher output voltage than 6V when the output is -say- unloaded?  Nevertheless  if the output can give shocks it may mean there is no any Zener voltage limiter inside?
Thanks,  Gyula
Jimboot
Quote from: gyulasun on April 14, 2010, 11:50:59 AM
Hi Jim,
Thanks,  Gyula
If it works happily at 20km/h then I should get charge at 1600RPM. VERY doable. The only question becomes how much drag is there.
Jimboot
A quick video update on my current rig. Just waiting for the dynamo. http://www.youtube.com/watch?v=CGGhk-jMPhc
gyulasun
hi Jim,
I'll keep my fingers crossed for your successful looping!
Will you use some extra mass on your present rotor and the would-be hub combination, I think here of a kind of flywheel effect whether it is needed to a certain degree, to store mechanical energy. I do not mean it is a must, just maybe, it all depends on total summed masses versus would-be "momentums".
rgds,  Gyula
