Newcomer to the overunity game, couple questions.
Started by GonnaTurnTheWorldAround, February 09, 2010, 12:16:18 AM
solinear
Sometimes I forget how picky people here are....
WilbyInebriated
Quote from: solinear on February 09, 2010, 06:55:29 PM
yeah good edit... i was about to point out that verb conjugation had nothing to do with your error wherein you used combine (which would equate to addition) instead of multiply.
nightlife
"BTW, don't forget that you can have voltage at 0 (or at least negligible) amps - it's called static electricity."
NO! Never count static electricity as containing o amprage or being negligible, especialy when looking to capture energy. You must always remember that energy can never be created, it can only be released and or captured. It takes work to release and or capture and our quest is to be able to release and or capture more then the work used. When we have released and or captured more energy then the energy used to do so, we have then achieved over unity.
Some forms of over unity have already been achieved such as in the form of fuel. The problem with fuel we use today is that it is easily controled becuase there is a limited supply of it. There is one fuel that can not be limited and or easily controled and that is water. There are some that say they have successfully utilized water as a over unity fuel source but we have yet to be able to duplicate what some have said to have done.
The most sought after form of over unity is by way of magnitic fields. Again some claim to have acomplished this but again no one has yet to replicate what has been said to have been done. This is the type of over unity I personaly seek to acomplish. Magnetic feilds represent energy in it's purist form. You can not have energy without it containing a magnetic field and you can not have a magnetic field without it containing energy.
Everything is energy. If you can see it, it is energized. If you can smell it, it is energized. If you can hear it, it is energized. If you can feel it, it is energized. If you can taste it, it is energized. Nothing is truly solid becuase everything is energy and or a combination of.
Good luck with your quest and just remember that energy is nothing more then a vibrance.
Bulbz
Quote from: nightlife on February 09, 2010, 07:48:54 AM
volts X amps = watts
You cant have a volt without a amp nor can you have a amp without a volt. Therefore you can not have a volt without a watt. They are all a configuration of the same and you can not have one without having the other two. Therefore:
Volts = work
Amps = work
watts = work
Agreed !... All three are as important as each other  ;)
Best regards.
Steve Ancell.
eavogels
An ad every second post. Is that not a bit too much?
