Thanks to ALL for your help!!
Mechanical Power Booster using Magnets
Started by George Jetsgo, February 17, 2010, 07:07:32 PM
Bulbz
Quote from: mscoffman on February 18, 2010, 11:00:49 AM
You need to prove your unit provides energy gain because if it
just provides gain of torque alone or RPM's alone we don't need
it, because quite frankly, we already have gears.
With all due respect... Yes we have gears, but George is talking about a device where the output rotates the same amount of degrees as the input. Even if it's not overunity, it could still prove to be more efficient than gearing down.
Best regards.
Steve Ancell.
Bulbz
I'm in the process of building my workshop at the moment. When I have done that, I will have a go at building my idea.
I will post the result back here when I have done that  8)
Best regards.
Steve Ancell.
mscoffman
Quote from: Bulbz on February 18, 2010, 12:21:42 PM
Gears are nearly 100% efficient, and N degrees in four seconds
is angular velocity just as RPM's is angular velocity but if
he increases torque not at the expense of angular velocity
then that is gain and gain is overunity, assuming all he has
is permanent magnets, no other fuel nor a motor and so on.
He can't get around things by making claims that imply energy
gain, then deny that he has gain, so he might as well jump
into the overunity fray now, especially if he has something
that works. He is going to have to come clean if he tries
to market his invention to those companies as they will
already know these facts.
:S:MarkSCoffman
Bulbz
Quote from: mscoffman on February 18, 2010, 03:37:39 PM
then that is  and gain is overunity, assuming all he has
:S:MarkSCoffman
I do see your point.
Also, if the shafts are rotating at the same speed, does that mean that it cannot be run as a closed-loop system ?. It seems like it could be classed as overunity, but definitely not perpetual motion. So George could be on for a winner, if he approaches the right people.
Best regards.
Steve Ancell.
mscoffman
Quote from: Bulbz on February 18, 2010, 07:05:22 PM
Also, if the shafts are rotating at the same speed, does that mean that it cannot be ran as a closed-loop system ?. It seems like it could be classed as overunity, but definitely not perpetual motion. So George could be on for a winner, if he approaches the right people.
@Bulbz
Let me at it if it is a torque amplifer...But, yes one could take advantage
of it with a crankshaft or those sun gears or whatever they are called.
I tend to think in terms of electronics but there are mechanical analogs
to almost everything electronic. One could make it a selfrunner with
the mechanical analog of a capacitor. Real overunity machines would
require full extraction and the disposition of the excess energy into
heat in a dynamometer kind of arrangement.
:S:MarkSCoffman
