Thanks to ALL for your help!!
Mechanical Power Booster using Magnets
Started by George Jetsgo, February 17, 2010, 07:07:32 PM
George Jetsgo
Your concept is not similar to mine.  Sounds interesting though.
I have made several models, and no matter how I sliced it, the machines did not work because the attracting magnets did not want to let go and the opposing magnets would not let you get there.
My breakthrough came when I discovered how to 'encourage' the magnets to 'let go and get there', effectively will little effort.
good luck
DMBoss
Quote from: George Jetsgo on February 17, 2010, 09:31:03 PM
I tried using an actuator, solenoid, electro magnet and about everything else up to a sledgehammer.  Nothing worked well, because the magnet was so hard to move.   I'm using some 150 pounders, and when they are nearly touching, it takes a lot of energy to move them apart.  I knew that in order to make this work, I needed help from somewhere.. and it came to me one morning when it was still dark outside.  It was too simple.  I jumped out of bed and started drawing.  This was last March.  Now this device is complete.  It is not patented yet, so I can not show the photos and I can only speak in general terms of how it works.  It has been very expensive to construct.  I now need to find someone or a group, that would be willing to help me build the next model.  Using my design concepts, I want to build this onto a recumbent trike or small 4 wheel cart.  I know that the energy a cyclist puts into a pedal will be enough to manipulate huge magnets and will produce more than what a conventional pedal system will transfer to the wheels.   Getting interest for this has been harder than solving the magnet lock obstacle.
George:
I may be able to help.  A lot of technical expertise in this area, as well as a fully equipped fab shop and testing lab, along with 2D and 3D simulations, including dynamics (mass, inertia, accelerations, spring constants etc.).
See my website:
http://qdmechanic.com/
And if you would, please contact me from at the email address there.
Yes, getting valid ideas funded is tricky, but the key is a working demonstration, or independant validation.
I can help on all these fronts, and if there is a working model, which can be demonstrated to produce a "gain" as you indicate, then overcoming the major hurdle of obtaining the resources to move forward is in hand.
However, while I have many examples of gains measured on the bench, I remain a tad skeptical as soooo many persons making such claims have not measured correctly!
There ARE ways to break Nature's tendancy to be reciprocal (in = out), but while you might have say 10 ways to do it, there are 10 million to not do it, or fail to achieve more output than input.
I am fine with NDA (Non Disclosure Agreement) to have an independent look at your concept and attempt to verify it in simulation as a start.  But we should talk privately about details and expectations.
Thanks,
DMBoss (QDMechanic.com)
ramset
George.
Its "your Baby"
This forum is more for folks looking to "Share" ways to make this planet a better place.
Sounds like you worked hard on this.
SOO??
People work hard every day,and they don't get to change the world!
You might??
Raising your Baby by your self ain't easy [but you will do it]
If you expect it to take care of you ?you may find the "Window" has passed you by?
Chet
PS
sounds like you have a power multiplier
Wind power is the first place I think of to benifit
Get exercise and"Playtime" out of your head Bud, this world needs solutions to "REAL" problems
Thanks Grandma
Paul-R
Quote from: George Jetsgo on February 17, 2010, 07:07:32 PM
I have invented a device to mechanically harness the super strong Neodymium Magnets. In simple terms this device uses a command magnet that activates a working magnet to turn a flywheel. The challenge has been, "how do you move the command magnet away from the working magnet once the magnets are nearly touching?" Conventional wisdom says that over unity is not possible...
Depending on your definition of overunity, conventional wisdom is wrong.
I can do no better than refer you to Patrick:
http://www.free-energy-info.co.uk
mscoffman
I have invented a device to mechanically harness the super strong Neodymium Magnets....
<-snip->
Any suggestions for the most likely vehicle or company to work with in this research?
thanks
@Jetsgo
What I would recommend is building, at low cost, the following
device:
Find out what this device can do, then insert your energy
amplifier between the motor and the generator. The same
way that Watts=Volts times Amperes for electrical energy.
Watts = constant * Torque times RPM's for mechanical energy.
You need to prove your unit provides energy gain because if it
just provides gain of torque alone or RPM's alone we don't need
it, because quite frankly, we already have gears.
This would allow you to quote the energy gain for your device.
In either case you will win because this device either produces
overunity energy itself and your invention will cause it to produce
more, or else your invention will push it over the line to have its
initial energy gain.
Quote from: joe tomicki on February 05, 2010, 09:45:28 PM
Just built this 500watt scooter moter 24v driving a car generator charging 10 12v golf cart batt. and a 5000watt inverter to power what you want . and charge the 24v batt. pack off the 10 batt.
Quote from: DreamThinkBuild on February 06, 2010, 08:01:08 PM
Neat Idea.
Just for reference would you go with a chain or belt driven motor?
http://www.electricscooterparts.com/motors.html
What type of car alternator would you use that has minimal cogging?
Thanks
Quote from: mscoffman on February 07, 2010, 01:32:29 PM
Good reference for motorscooter motors, Thank you. 12Vdc Car Alternators
are generally 400watts or 800watts for heavyduty. There are truck
alternators with even higher ratings. Alternators are actually 3phase AC
generators with a diode set setup to produce 12Vdc. Remember car/truck
alternators require a 12Vdc Regulator either independent, or built-in to
keep batteries charged. Regulators set the field coil current levels to
the alternator based on battery voltage and external demand levels.
Obviously a 400watt max alternator should not cog a 500W motor
to a standstill. The Alternator will then brake the motor only enough
to charge the 12V batteries back up. Lift truck, golfcart, and trolling
boat motor batteries are called "deep cycle discharge" batteries, do
not use normal car batteries as they are not deep cycle discharge.
It would be interesting to know the optimum gearing or belt pulley ratio
(diameter) he used to link the two units to maximize efficiency.
Quote from: mscoffman on February 11, 2010, 11:19:47 AM
A pictorial reference for a car alternator;
http://www.free-energy-info.co.uk/Chapter2.pdf
...pages 57 through 81
The alternator used in above reference has a built in
battery regulator. With apologies for the off topic posts.
:S:MarkSCoffman
