Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 110 Guests are viewing this topic.
ltseung888
Quote from: The Observer on November 15, 2010, 01:30:32 AM
Chris,
There is no Over-Unity,
                                    there are only
                                                         Unrecognized Sources of Energy (USE).
Best Regards,
                     The Observer
Dear Observer,
I believe we are moving roughly in the same direction.  You believe that there is Unrecognized Sources of Energy (USE).
I believe that scientists have not recognized that Existing Gravitational or Magnetic Energy can be lead-out or brought-in into a “device”.
Your resonance example is excellent.  That is definitely a direction I shall take in the coming weeks.
Wishing you the best and a Happy Thanks Giving.
Lawrence
The Observer
LT,
Thanks for your well wishes.
1. A roomful of tuning forks vs.1 tuning fork when only 1 is struck should stump just about anyone.
    It will ring louder and longer (a roomful).
2. A FerroMagnetic Substance can amplify the Magnetic Field of a coil up to 1,000,000 times (without using extra current)
                                B = (μ0 * μr * N * i) / l
        μr is the Magnetic Permeability of the material within the solenoid.
     Thanks to the magnetic dipoles
     powered by free unpaired electron spin.
3. If you take your best Joule Thief... and tune it to Resonate an Ignition Coil.. you can light a CFL.
4. If you do #3 and Resonate a roomful of Ignition Coils... it is probable that you would have lightning bolt at your disposal.
Best Regards,
                    The Observer
P.S. I suggest checking out the Captret Thread.
       People are doing some very interesting yet simple experiments with Electrolytic Capacitors.
       Apparently there is a 3rd.. never mentioned connection to an E Cap that exhibits some interesting properties.
Pirate88179
Quote from: The Observer on November 15, 2010, 11:34:58 PM
LT,
Best Regards,
                    The Observer
With due respect, you keep posting this stuff over and over and, I am afraid you will confuse the newer folks.
So, to set the record straight, you CAN light a cfl WITHOUT a secondary ignition coil using a well designed JT circit...yes, a regular one.  You can also light a cfl using an air core with NO ferrite.  It has been done many times and I do not know why you seem to ignore this.
Now, would a JT connected to an ignition coil be pretty cool?  Possibly, so DO IT and quit writing about it and we can all see together what it will/or will not do.
But, one does NOT need an external coil, ignition or any other kind, to light a cfl with a dead AA battery.  So please quit saying this as a fact when it is not.
Thanks, I hope I was not too harsh but, again, I am concerned for the newer folks coming in here that might think this is the only way to light a cfl with a JT.
Koen1
Bill is right. You can run a CFL on a single JT if you do it right.
Additional hV generators such as ignition coils are not really necessary.
In fact, I've run small FL tubes on a JT powered by a nearly dead battery,
with only one wire terminal connected to one of the FL tube's elecgtrodes,
and the other wire not connected to the tube at all, just coiled around the
glass of the tube. Works fine.
Seems to be more the EM that drives the tube than the actual current...
I have also run a pulsed transformer off my JT, with neo magnets attached
to the trafo core at strategic spots. Needed quite some tuning, but it worked.
Was basically a setup much like the MEG, but much smaller and simpler.
pese
Quote from: Koen1 on November 16, 2010, 08:53:37 AM
It will work
but it suck the battery EMPY!
It hae never mor output that it need Input power.
So you can ot fill-up emty batteries with ths circuits.
IF.... you suck more power from the Inout "off"
Open your eyes and mind
Pese
www.alt-nrg.de/pese
German/English alternative Link Collections
