Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 124 Guests are viewing this topic.
WilbyInebriated
Quote from: pese on November 16, 2010, 10:15:59 AM
It will work
of course it will
but it suck the battery EMPY!
that is a joule thief's purpose... this is what they are designed to do... do some research about a joule thief. reading is fundamental.
quote from big clive: "I originally called this torch the vampire torch because it sucked the last remnants of life from a cell, but then decided to call it a Joule Thief instead because it was a catchy name and played on the fact the unit steals the last bit of energy from a cell. (Joule is a unit of energy) I guess the name has kinda stuck!"  http://www.bigclive.com/joule.htm
It hae never mor output that it need Input power.
i don't see where koen claimed any such thing.
So you can ot fill-up emty batteries with ths circuits.
yes you can, with the addition of feedback.
Open your eyes and mind
please practice what you preach.
ltseung888
Quote from: Koen1 on November 16, 2010, 08:53:37 AM
Bill is right. You can run a CFL on a single JT if you do it right.
Additional hV generators such as ignition coils are not really necessary.
In fact, I've run small FL tubes on a JT powered by a nearly dead battery,
with only one wire terminal connected to one of the FL tube's elecgtrodes,
and the other wire not connected to the tube at all, just coiled around the
glass of the tube. Works fine.
Seems to be more the EM that drives the tube than the actual current...
I have also run a pulsed transformer off my JT, with neo magnets attached
to the trafo core at strategic spots. Needed quite some tuning, but it worked.
Was basically a setup much like the MEG, but much smaller and simpler.
quite some tuning
That is the experience from our various teams also.  Too little or too much will shift away from the delicate balance.  One must have the patience and exert the extreme care.
With the right equipment (e.g. the two oscilloscopes), the tuning is much easier.
Koen1
It will work
Yes, of course. That's what batteries are for, to give energy untill they're empty.
QuoteIt hae never mor output that it need Input power.
Really? Well, I suppose you know more than me then.
I expect you have tried it in all kinds of variations? Or are you just
blowing hot air?
QuoteSo you can ot fill-up emty batteries with ths circuits.
Again, oh great oracle, I presume you have tested this?
I have, and I did get more out than in. Not considering the energy needed
to make the magnets, of course.
But surely you won't be shouting things without good reason?
QuoteIF.... you suck more power from the Inout "off"
No clue what you mean to say with that sentence.
Do you mean to say "you can not fill up empty batteries with these
circuits, if you suck more power out of the output side"?
Then I still don't follow what you mean to say.
After all, there's no "sucking out", there's "pumping in" and
"getting out". You're never supposed to "suck out" energy
on the output side, you always "collect" the energy coming
out. "Sucking" implies actively pulling the charges out of the
output side; that does not happen. The output is actively
being "pumped out" on the output side, and you only need
to "passively" collect that.
QuoteOpen your eyes and mind
open your English grammar and idiom books and please
state clearly what you mean to say?
Pese
www.alt-nrg.de/pese
German/English alternative Link Collections
[/quote]
WilbyInebriated
Quote from: Koen1 on November 16, 2010, 10:41:50 AM
oh, but now koen is claiming "more out than in"... i hope data, measurements and the experiment is posted to support this amazing claim.
The Observer
Pirate,
Let me get this straight.
You are complaining that I am repeating my idea.
Meanwhile, you got the hecklers that---> repeat<--- the same thing day in and day out and you don't complain ?
What gives?
Just to be clear.. I will repeat my good idea as long as the hecklers repeat their bullshit.
I am hoping I am as annoying to them, as they are to me.
Meanwhile.. it doesn't hurt to spread the message about how Ferromagnetic Materials Work.
                   or that Resonating Certain Objects produces results that look a lot like 'Over-Unity'.
I never did say the only way to light a CFL with a JT was to Resonate an Ignition Coil.
I am saying.. and I'm pretty sure you agree.
You can't light a CFL with Joule Thief
        for a long time.. unless                            you use a Ferromagnetic Core of High Magnetic Permeability
        or
                                                           Resonate a Transformer that does not have a core of High Magnetic Permeability.
        or
        Resonate  an External High Voltage Ferro Transformer.
If there's another way to to do it.. then let me know and I will add it to the list.
I think you are overlooking the Fact that you need a Ferro Core or Resonance.
Perhaps you just don't think it's as important as me.
1. I find it amazing --- that a Ferro Core can amplify the Magnetic Field of a Coil by 1,000,000 times without any extra current.
                                          B = (μ0 * μr * N * i) / l
                                  μr is the Magnetic Permeability of the material within the solenoid.
2. I find it amazing --- that 2 tuning forks ring louder and longer than 1 when only 1 is struck.
Best Regards,
                     The Observer
