Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
FatBird
Could someone please post where we can DOWNLOAD the Magnacoaster patent pages.
Thank you very much.
ltseung888
Quote from: FatBird on March 18, 2010, 12:26:46 PM
Diodes 100a and 100b are still REVERSED.  Look close at it and you will see the battery will never get charged the way it is.
In fact, WHY even have the bridge in there?  Bridges are only used to convert AC to DC.  Diodes 102 and 104 already supply DC.
Hmmmmm, if they can’t get a simple thing like that right, what else is printed WRONG???
Thank you FatBird and Pese,
I always know that we can learn together â€" even from the mistakes of others.  We can insult the inventor or help to correct his mistakes.  Some mistakes are likely to be typos or clerical.  Others may be incorrect assumptions.
I shall be brave and propose the attached diagram.  If the recharging of a battery using lead-out energy is that simple, all the electric car designs can change.  ;) ;)
pese
Yes that is it.
nomal way i can alsi remove diodes 100a 100b 102 and 194 , Only setting the bridge in right way that the polarities shown the RIGHT way to the battery.
It do not need to loss mor than 2 volt in "unneed diodes".
als the 1volt losses in the bridge, you can reduce, with SCHOTTKY diodes. Do not buy.  THAKE THEM OUT from your old PC Supplies.
They contains 2 x 35 or 50 Amp Diodes.  + (2 diodes in one case.
look like Transistors with 3 leads)
Try it. This is the way to reduce all losses.
IF the circuit will bring you overunity ?
I an not a "typically NOsayer.
So i hope it.
G Pese
ltseung888
The onion skin peeling approach in layers
Each layer reveals more detail.
1.   Lead-Out Energy Theory does not violate the Law of Conservation of Energy.
2.    Gravitational and Electron Motion Energy can be lead-out.
3.   Pushing a pendulum at the right time can lead-out gravitational energy.
4.   Pulsing a magnetic pendulum at the right frequency can lead-out electromagnetic energy.
5.   Technique can be extended from oscillation to vibration, to rotation and flux changes.
6.   The energy field can be gravitational, magnetic, electric or electromagnetic.
7.   Higher efficiency is available from rotational systems.  Pulse rotate magnets and/or electromagnets in a wheel type arrangement can lead-out electron motion energy.  This can be confirmed with the Tong Wheel in Hong Kong.
8.   Motionless Electricity Generators (MEG) can lead-out electron motion energy based on flux changes. No physical motion is needed.  The size of a MEG can be small.
9.   DC Pulse from the Primary Coil of a transformer can lead-out electron motion energy from the surrounding to the Secondary Coil of a transformer if that is a resonance circuit.
10.   Examples of MEG system information are available from the late Stan Meyer, Bob Boyce, etc.
11.   MEG product is available NOW from Magnacoaster.
12.   There is possibility that FLEET (Forever Leadout Electromagnetic Energy Transformer) can be built from having LCR resonance circuits in the Secondary.  The Primary provides the resonance frequency to pulse and lead-out electromagnetic Energy.
13.   FLEET will not be patented and any individual or organization with a Pulse Generator, an Oscilloscope, a toroidal transformer, multimeters, capacitors, inductors, resistors, diodes and basic electronic equipment and skills  can build a FLEET for demonstration.
14.   The starting point can be choosing a capacitor, an inductor, a resistor and use the LCR resonance calculator from the Internet to calculate the resonance frequency.  Part of the inductor is the secondary coil of the transformer.  The initial test can have equal number of turns in the Primary and Secondary Coils.
15.   In the special case of the Stan Meyer HHO water cell, the capacitor is from the plates in the water cell, the resistance is from the electrolyte.  The inductance is from the secondary coil, a fixed coil and a variable coil.  Some diodes were used ensure DC Pulsing.  Brown’s Gas (HHO) is produced in large quantities at resonance when electromagnetic energy is lead-out (or bring-in) from the surrounding.
16.   The non-expert but interest individual or organization can purchase MEG products from Magnacoaster for evaluation and testing NOW.  There is no need to speculate and doubt the validity of the technology.
17.   The technical minded individuals or organizations can build FLEET for experiments.  They can compete to produce PRODUCTS now.  There is no patent and it is an Open Race.  The Market potential is in multi-trillions.
18.   The World will see a fleet of FLEET products at low prices in the coming months.  The World Energy Crisis will be over.  A new World Order will emerge.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
wattsup
Hello All
Sorry to but in. Seems to be a habit of mine these days but I just ran across this thread and wanted to show you guys something I had made a few weeks ago.
In the photo you can see this is just an off the shelf transformer that has a round core with two coil sections having various primary and secondary already on it.
So I had decided to just saw one end of it and then forced open the aperture to fit some neo magnets in between the cut. I think this makes about the same type of coil as on the page 1 of this thread without the hassle of building, plus you get an already known build that must have some published specs somewhere.
The main mistake I made is to stupidly do the cut before I did any preliminary testing with the coil as is, for comparison purposes. But I can say that with a weak pulsing generator, I am getting very very coupling from the other coils. But I cannot compare it so I don't know.
Anyways, it is just to show that if anyone wants to do more testing on this, just find two of these transformers and do the testing. I am working on too many other things right now so again, sorry for the intrusion.
Oh, just to mention that you cut make two cuts on this transformer and have two nice coils for any type of rotating magnet wheels, or putting more magnets from two sides, etc.
wattsup
