Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
Bruce_TPU
Quote from: ltseung888 on March 24, 2010, 07:50:49 AM
Someone sent this personal message
I do not appreciate such personal mails.  Slanderous statements without any supporting evidence will be ignored.   :-\ :-\ :-\
Dr. Mark Snoswell is very reputable and has a very keen mind.  He is correct about Magnacoaster.  A personal Friend of mine tested the device, with the inventor.  Said inventor stole friend's controller and another piece of electronic equipment.  Not very reputable.  Said unit does not work as advertised.  Sorry.
Dr. Snoswell has also personally seen "real" working devices, some of which I have personel knowledge of.
He is a "genuine" researcher with more credability than most that I have met.  He was trying to point you away from misdirection is all.
Again, I hate to insert myself into these things, but I have personal knowledge of some of these matters.
Have a good day,
Bruce
ketone
Magnacoaster is a fraud?.....then why the warranty?
http://www.vorktex.ca/page/181134205
Looks like they put quite an effort in getting this off the ground and for what...an elaborate hoax?
ltseung888
Quote from: Bruce_TPU on March 24, 2010, 11:22:59 PM
Have a good day,
Dear Bruce_TPU,
Thank you for your good information.
I have the Tong Wheel that can be confirmed to produce overunity results available for verification in Hong Kong.  I have done the experiments in reply 72.  Those experiments confirmed that presence of permanent magnets close to electromagnetic coils acting as Collector Coils could indeed affect the magnetic flux.  Greater Output Power can be observed and measured.
The arrangement in reply 72 is simple.  However, it hinted to the feasibility of the Magnacoaster device.  I shall reserve judgment on the Magnacoaster device as I shall have one to work with myself  within the next few weeks.
I shall have a Stanley Meyer type HHO generator type car to examine in China.  It is supposed to be working now.  The development of that generator was via the late Yull Brown approach.  I met Mr. Brown and saw his experiments with my own eyes.  His generator was a China-made Brown’s Gas Generator.  I posted the information on the Internet.  You can do a google search â€" keyword “Lawrence Tseung Yull Brown”.
The crowning glory will be FLEET.  The principle is sending Pulse DC via the Primary Coil of a transformer to the Secondary Coil.  The Secondary Coil is part of a resonance circuit.  The frequency of the Pulse is the resonance frequency.  Three independent groups in Hong Kong/Shenzhen got promising results but refused to share the information with the World now, as they are in the product design stages.  There is no patent protection available for FLEET. The Stanley Meyer circuit is simply an example of such an arrangement.
I shall have my own space and loaned equipment from the Hong Kong Invention Association members in the coming weeks.  I do not mind sharing my results.   I have received comments and insults that the Tong wheel could never work (see the Lee Tseung Lead-Out Energy theory thread).   I also failed numerous times with 6 different groups before getting the overunity result.  Tuning for resonance is a very painstaking and painful job.  It took me a few weeks to tune the Tong Wheel.   Should I believe the debunkers, on-lookers, failed experimenters or insulters?
Or should I believe in the Lead-Out Energy Theory and the successful, repeatable but hard-to-obtain experimental results?
ltseung888
Quote from: ltseung888 on March 23, 2010, 01:59:47 AM
Dear Sir,
Greetings from The A Asia!
My name is Eva Yim from The Wall Street Journal Asia,( asia.WSJ.com ) and I am contacting you in regards to the 2010 Asian Innovation Awards presented by The Wall Street Journal Asia and in partnership with Credit Suisse. Enclosed please find a press release on the Asian Innovation Awards, for more information on the Awards, please visit asia.com/aia
The Wall Street Journal Asia, the leader in global business news for Asia, is now accepting entries for the prestigious Asian Innovation Awards 2010. The Asian Innovation Awards are committed to finding the next big ideas in Asia, from entirely new inventions to the advancement of a classic. We are seeking innovations that break with conventional processes in creative ways to improve quality of life or productivity. We would like to take this opportunity to invite you to submit entries for the 2010 Asian Innovation Awards. Please be advised the submission deadline has been extended to April 9, 2010.
Nominations are free, there is no cost involved and the top 12 finalist of The 2010 Asian Innovation Awards will gain editorial coverage ( each finalist will have 1 full page coverage on their invention in The Wall Street Journal Asia as well as online at asia.WSJ.com ). This is an extraordinary opportunity for individuals or organizations to get recognition onto the world stage. I have also attached the print ad which is running in The Wall Street Journal Asia as well as in other publications such as Forbes Asia, Telecom Asia,etc.
If you have further questions regarding The 2010 Asian Innovation Awards, please don’t hesitate to contact me. However, in case there is a need for me to contact another person within your organization, it will be great if you can pass this information accordingly to the appropriate person-in-charge.
Thank you for your help in advance.
With kind regards,
Eva Yim
Assistant Marketing Manager
Dow Jones Publishing Company (Asia), Inc.
a: 25/F, Central Plaza, 18 Harbour Road, Wan Chai, A
t:  +852 2831 2585       f: +852 2503 1537
Just received a phone call from Wall Street Asia.  They confirmed interest in our invention and planned to have experts to check out the Tong Wheel.  The Tong Wheel is also in Wan Chai, Hong Kong - a few streets away from their Office.
I believe after examination from their experts and published in the Wall Street Journal Asia, the Tong Wheel will have the credibility.
We plan to have a version of FLEET ready at the same time.  Life is fun with such welcome pressure. :D
ltseung888
An early Easter Message
The curtains in the apartment had mold on them.  That could be dangerous to health.  I took them to a Commercial Laundromat  as the home washing machine is too small.  I tried one curtain first.  The owner said that she had seen such molded curtains before.  Some got cleaned with no problems.  Others came out winkled and torn.  I said, “Give it a try.”  I have not done it before and just hoped for the best.
The next day, I got the bad news.  The curtain sheet had elements of plastic and melted in the drying process.  The Laundromat workers took it out while it was wet to prevent further damage.  It was a failed experiment.
I then called a friend who was trained as a professional home cleaner.  She said, “You can get rid of the mold with household bleach.  Just make sure that you thoroughly wash it afterwards.”  I poured some bleach on a piece of cloth and started rubbing the mold.  The mold came off and the sheet looked very white.  I was delighted and rubbed more.  I thought that it was a success.
After about 5 minutes rubbing, I felt pain in my hands.  Apparently, I suffered a small cut due to the rubbing and the bleach acted directly on the flesh.  I thoroughly washed my hands and was about to give up.
Then I read the post that someone remarked that the Magnacoaster and Stanley Meyer devices did not work.  According to the Lead-Out Energy Theory and the preliminary proof-of-concept experiments, they MUST work.
I then put on thick rubber gloves and used a tooth brush dipped in the bleach to rub the mold.  It was a slow, painstaking and painful task.  However, it worked.  I do not need to buy new curtains!
The Easter message is â€" the Professionals in establishments do not know everything.  They can be wrong.  (Just like the patent offices and established scientists).  Someone much less qualified may give the correct advice but they may not spell out every detail (just like the posts on the Internet).  The actual experiments may not be successful in the first try.  One must persevere, examine the evidence and modify the procedures.  When the final successful result is demonstrated, many others will say â€" it is easy and obvious. (just like the Stan Meyer circuit or the FLEET devices).
To the overunity device inventors:  The Lead-Out Energy Theory says that if energy can be led-out (or drawn-in) from the surrounding, there is no violation of the Law of Conservation of Energy.  Your device may be a form of Lead-Out Energy Machine.  Do not get dejected and give up.  Be prepared to modify and improve your set up or techniques.  Success is only around the corner.
