Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
To Magluvin,
Thank you for your quick work.  Please consider doing more in light of the new information.
It looks like the FLEET is simple to understand and implement.  The breakthrough is really the use of Pulsed DC.  Put a permanent magnet in the core of a transformer and electron motion energy can be lead-out.  The added manufacturing cost is minimum.  The added electronics are reasonably standard.
The Magnacoaster patent and products confirm the theory.  However, they did not seem to have covered the "transformer" case in their PCT filing.  That opens a wide door for the World.  May be it is their deliberate policy.  Or it may be the will of the Almighty to ensure that the World benefits.
One of our team members is working on the loopback mechanism.  We shall be using thick wires.  If the loopback mechanism works, the power can be magnified 1,2,4,8 ... times  This is theoretically possible.  The size of the unit can be small.
Continue to have fun.
ltseung888
Quote from: Paul-R on March 05, 2010, 07:18:12 AM
Aren't we going to get BEMF happening on both sides? i.e. at the input A
and the output coil? If so, we will need diodes to protect the 555 from
getting some dreadful voltage which will need, instead, to be routed through a bridge
rectifier probably into a battery.
Do not get too hung up on BEMF.  That will not explain the extra energy.  It appears that the FLEET acts like the normal transformer with step-up and step-down functions.  It is Pulsed DC.  But the Power (energy) is magnified from the Lead-out energy.
The magnification may depend on how many times the Output is looped back.  Some program control will be needed eventually.
ltseung888
The Stan Meyer Water Fuel Cell Circuit
There will be a HHO car invention in Hangzhou using technology similar to the late Stan Meyer.  I am supposed to explain its workings with the Lead-Out Energy Theory.
The whole point about the Stan Meyer technology is that the energy needed to split the water into hydrogen and oxygen is far less than that when the hydrogen and oxygen gases recombine.
Look at the Circuit.  It is just a Pulsed DC Transformer!    Less energy is drawn from the battery because Electron Motion Energy is lead-out from the surrounding by the set up.  The explanation is easier than I thought.
ltseung888
Need confirmation on the EI A when Pulsed DC is used
One suggestion is to replace the middle rod in the E core with a permanent magnet.  Since the primary and the secondary coils are wound concentrically around this rod, this may be another alternative set up.
Things are getting more exciting and fun!
ltseung888
Second Test with timer
The test was as follows:
1.   Use Timer ON/OFF as Pulse.  Set to 0.1 seconds.  There was about 50-70mV across the Primary Coil when there was no Secondary.
2.   Then measured the Secondary to check whether there was transmission.  There was about 5mV across the Secondary.  This means some transmission.  The loss was high as the number of turns are approximately equal.
3.   When one A was used, there was 0 transmission in one direction.
4.   In the other direction, there was some transmission.
The test was inconclusive.  However, it pointed to the following:
A.   A Pulse Generator is desirable.  The frequency can be easily adjusted.
B.   Cut down the loss as much as possible.  The loss in the set up was more than 90%.  That made validation impossible.
C.   The use of magnet in one direction appeared to give different result than in the other direction.
D.   May need to use thicker wires, higher current, better C-core and higher frequency if we want to get better results.  (Especially to demonstrate overunity).
However, the test is worthwhile and fun.
