Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 145 Guests are viewing this topic.
Paul-R
Quote from: ltseung888 on March 05, 2010, 04:14:46 PM
Do not get too hung up on BEMF.  That will not explain the extra energy.
It will contribute to more of it, but also, it will blow the 555 if we allow
around 750volts to go hurtling at Pin 3.
The Observer
Mr Tsueng,
I don't wanna get too negative... as I am a fan of your work.
However, I have no idea how you think adding a magnet to a transformer would make it work better.
          What makes a transformer interesting is the fact that the core turns into a magnet.
                The core DOES NOT conduct magnetism as is suggested by many sources.
                The core AMPLIFIES magnetism as is described by it's Magnetic Permeability.
                   - the core is switchable magnet needing little energy to affect a change.
                   - the difference between a solenoid's magnetic field with and without core is on the order of 10,000 to 1
                   -putting a magnet in the core is going to decrease the amount change the core can make.
                   -energy transfer/production depends on how much the magnetic field changes.
So I hope you can see why I am curious of how you think this might work?
Please let me know how restricting the dipoles in core from turning would make it more efficient.
The Observer
P.S. From what I have observed on transformers, an interesting situation is that of Resonance.
        At resonance you will find large pulses on both sides (  Primary and Secondary )
ltseung888
Quote from: The Observer on March 06, 2010, 10:40:53 AM
Mr Tsueng,
I A't wanna get too negative... as I am a fan of your work.
However, I have no idea how you think adding a A to a transformer would make it work better.
          What makes a transformer interesting is the fact that the A turns into a magnet.
                The A DOES NOT conduct magnetism as is suggested by many sources.
                The A AMPLIFIES magnetism as is described by it's Magnetic Permeability.
                   - the difference between a solenoid's A with and without core is on the order of 10,000 to 1
The Observer
Dear Observer,
The trigger experiment that led me to believe the presence of a permanent magnet will affect the lead-out energy mechanism is shown in the diagram.  The Tong Wheel demonstrated the reality of the Lead-Out Energy Theory.  However, it did not reveal the best lead-out mechanism.
In your understanding of the Pulsed DC Transformer, you should add an element â€" Lead-Out Mechanism which is NOT fully understood by Lee Cheung Kin and Lawrence Tseung yet.  Why the presence of a stationary permanent magnet lead-out more energy is unclear!  But it is an experimental fact.  The JNadin experiment described on reply 50 also confirmed our experimental findings.
Life is full of surprises and fun.
The Observer
Hello Mr Tsueng.
Thankyou for your reply.
I guess you have some reason to believe a magnet would help.
However, I may suggest that the iron in the core is the real source of the energy
                although I have noticed an unusual effect when a magnet is an inch or two from a piece of iron.
                That is the domains in the iron will remain turned in the direction of the magnet when brought from the magnet.                         M--->I
                But when brought to the same place from a spot away from the magnet... all domains don't turn. (the iron isn't fully magnetized)   M     I<---
                Bottom line.... same spot in space,
                                        but different magnetism in the iron.
                                        This may be how the wheel worked,
                                        by breaking the fragile hold of the magnet by a pulse to the coil wrapped around the iron.
Anyways... by all means keep it up.. I am interested in this.
The Observer
ltseung888
Quote from: ltseung888 on March 05, 2010, 10:19:28 PM
The Stan Meyer Water Fuel Cell Circuit
There will be a HHO car invention in Hangzhou using technology similar to the late Stan Meyer.  I am supposed to explain its workings with the Lead-Out Energy Theory.
The whole point about the Stan Meyer technology is that the energy needed to split the water into hydrogen and oxygen is far less than that when the hydrogen and oxygen gases recombine.
Look at the Circuit.  It is just a Pulsed DC Transformer!    Less energy is drawn from the battery because Electron Motion Energy is lead-out from the surrounding by the set up.  The explanation is easier than I thought.
Note that the Stan Meyer circuit uses toroidal core.  That core does not contain a magnet.  However, there are two coils on the outside circuit.  One of them is variable.  I believe the setup already acts as an auto feedback device.  The energy is used to electrolysis water which can represent a constant load.  The variable coil will be able to change the rate of current flow.
This implies that we may not need a magnet inside the core to produce the lead-out energy effect.  That makes the construction of the FLEET much easier.  FLEET stands for Forever Leadout Electromagnetic Energy Transformer.  It will still apply to the Pulsed DC Transformer with NO embedded magnets.
Surprised to find my articles on the late Prof. Yull Brown available on the Internet:
http://www.autosdrive.tk/reyull-browns-gas-brown1
The immediate gases from electrolysis of water is sometimes called Brown's Gas.  It has unusual properties as described in the above articles.  Make sure you use it immediately.  Storing them for hours may produce the dreaded mixture of explosive hydrogen and oxygen.
Life is getting  more exciting â€" even for an old folk like me!
