Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
Talk with a LED gift merchant
Merchant: “What is so special about the FLEET technology?  Can it be implemented in my products?”
Tseung: “If some of your toy products never need to replace batteries, would that improve your sales and profits?”
Merchant: “Now I am interested.  When will it happen?”
Tseung: “Do you want to see the primitive prototype?  We took apart some of your products and added some of our inventions.”
Will the first FLEET LED Fan toy hit the market by Christmas 2011???
*** Technology base
1.   Basic LED
2.   LED with Joule Thief Technology
3.   LED with enhanced Joule Thief Technology and feedback
4.   System with muscle and/or solar recharging (starting and maintenance)
5.   Integrating and packaging
ltseung888
Conversation with Engineer F
Engineer F: “I got your information from my friend who intends to build a FLEET toy.  He showed me the websites and your contact information.  I have a few questions.  Will you answer them?”
Tseung: “Sure.  As I have stated many times before, I do not consider myself as the inventor.  It is the Almighty performing miracles through me.  The information is for all to share and to benefit the World.  What are your questions?”
Engineer F: “In your example of a horizontally pulled pendulum with a force F, there will be equilibrium of the three forces, the tension of the string T, the weight Mg and the force F.  You are correct in stating that tan(a) = F/Mg.  The horizontal displacement is Lsin(a).  The vertical displacement is L(1-cos(a)).  I also agree with the above mathematics.  However, I have some doubts on the calculation of the horizontal work.  You used the simple formula of horizontal work = F * Lsin(a).  I believe that the force F may not be constant.  Can you explain that?”
Tseung: “You are very observant.  You are the first one to raise the question in this manner.  Indeed, you can theoretically apply a force smaller than F initially on the pendulum bob and the pendulum bob will also move.  The more exact formula should be the integral of F(x)dx.  The force F(x) can indeed vary as a function of the horizontal displacement.  However, for clarity of understanding, I made the simplification of using a constant force F.  That is the largest force needed.”
Engineer F: “Does that mean that you can apply less energy to lead-out a given amount of vertical gravitational energy?”
Tseung: “Yes.  No matter how you look at it.  No matter how you do your calculation, you will get lead-out gravitational energy so long as there is tension at the string.”
Engineer F: “If I accept that we can extract or lead-out gravitational energy, how can I extend the same concept to electrical energy or electron motion energy?”
Tseung: “You can do the Forever Yuen experiment.  Replace the pendulum bob with a magnet.  Place the magnetic pendulum bob in an external magnetic field produced by your own powerful magnets.  The period of oscillation will change.  If you can extract gravitational energy, you must be able to extract magnetic energy.”
Engineer F: “I see the logic now.  If I can extract magnetic energy, I must be able to extract electrical energy.  Electrical and magnetic energy are closely related.  The orbiting electron around the nucleus produces magnetism.  That is why you believe that electron motion energy can be extracted via an appropriate pulsing electromagnetic field.”
Tseung: “Correct.  Now you can build your FLEET toy with confidence.  It is based on solid physics and mathematics.  Your toy does not need to totally use the chemical energy of the battery.  Much of it can be from the lead-out energy of the surrounding.  If you have proper feedback, that lead-out energy is theoretically infinite.”
ltseung888
Conversation with Aaron512
Aaron512: “I checked the mathematics.  The simplified version did show that 2 parts of horizontal energy will lead-out 1 part of vertical energy.  Why is this not taught at schools and universities?”
Tseung: “The most common assumption at Schools and Universities is that there is change from potential energy to kinetic energy in the swinging of a pendulum.  Any supplied energy will contribute to one of these two forms.  There is no consideration that gravitational energy can be lead-out via the tension of the string.”
Aaron512: “But if lead-out energy is correct, the World Energy Crisis is over.  The mathematics is so simple.”
Tseung: “When I go to USA, would you be willing to act as the coordinator in Hong Kong?  The task is to post some comments on the various forums; attend some meetings and give some seminars or workshops.  There are occasional exhibitions such as the Inno Tech Design Expo 2010.  I shall leave all material including the oscilloscopes for you.”
Aaron512: “That sounds like a good deal.  However, I may not do things the way you do.”
Tseung: “I know.  You already expressed your feeling that I was stupid in disclosing all my hard earned knowledge freely on the Internet and received insults.”
Aaron512: “I got the variable capacitors for you.  They may just be good for trimming.  I am working on the variable inductors.  Hope that will be better.”
pese
tHIS MODEL IN YOUR PICURE is an japanese
Model that was usedes in the end of 1960 jears
in japaneseAM FM tube Radios Reveivers.
aswl in high cost home transitor receivers.
al portabel transtor radios have uses PVC/Mylar trimming varabels (small sized.
I found my company in the 60s , with repairing
japanese transitor receivers for 3 of the biggest warehouse in germany.  So i find experiences and knowledge.
G.Pese
www.alt-nrg.de/pppp
alternative link collections
2002-2010  german/englisch
Paul-R
yes.
The coarse tuning is done with a capacitor box. The variable cap is of
low value and is only used for the last piece of tuning, the polishing, as it
were.
