Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 120 Guests are viewing this topic.
Paul-R
Quote from: ltseung888 on March 11, 2010, 12:20:58 AM
Bob Boyce
It probably never dawned on him to apply the circuit to other loads and not just the water fuel cell capacitor...
I think he has; the B-Hex device. I believe he has a microprocessor sending computer controlled pulses to one coil
http://peswiki.com/index.php/Talk:Directory:Bob_Boyce_Hex_Controller
Bruce_TPU
Bob Boyce
One of the important names in the HHO generation technology is Bob Boyce.  I listened to one of his interviews.  He also used toroidal transformers â€" same technique as Stan Meyer.
That is the power of knowing the Lead-out Energy Theory.  The Magnacoaster device works.  The Bob Boyce device works.  FLEET must work.  It is a matter of tuning.  One needs to select the range of output current and voltage or the load before tuning.
I expect the tuning will involve frequency, voltage, current, turns of coil in primary and secondary, the type of core material, the resonance coils in the secondary and the load.  A varying load will shift the resonance frequency.
Bob Boyce did much good work and shared the results of his research.  Great Guy.
Yes he is a great guy.  And he has experimented with other loads besides HHO.  Beware of making assumptions.  About people and devices.  Have you seen the magnacoaster info work?  Just because you see a patent pending does not mean that it works.  Another assumption.  There seems to be a lot of them in this thread.  Sorry, but just how I see it.
Have a great day,
Bruce
ltseung888
LC and RLC circuit explained
From http://en.wikipedia.org/wiki/LC_circuit
Simplified overview
An LC circuit can store electrical energy vibrating at its resonant frequency. A capacitor stores energy in the electric field between its plates, depending on the voltage across it, and an inductor stores energy in its magnetic field, depending on the current through it.
If a charged capacitor is connected across an inductor, charge will start to flow through the inductor, building up a magnetic field around it, and reducing the voltage on the capacitor. Eventually all the charge on the capacitor will be gone. However, the current will continue, because inductors resist changes in current, and energy will be extracted from the magnetic field to keep it flowing. The current will begin to charge the capacitor with a voltage of opposite polarity to its original charge. When the magnetic field is completely dissipated the current will stop and the charge will again be stored in the capacitor (with the opposite polarity). Then the cycle will begin again, with the current flowing in the opposite direction through the inductor.
The charge flows back and forth between the plates of the capacitor, through the inductor. The energy oscillates back and forth between the capacitor and the inductor until (if not replenished by power from an external circuit) internal resistance makes the oscillations die out. Its action, known mathematically as a harmonic oscillator, is similar to a pendulum swinging back and forth, or water sloshing back and forth in a tank. For this reason the circuit is also called a tank circuit. The oscillations are very fast, typically hundreds to billions of times per second.
A pendulum pushed at the right time can lead-out gravitational energy.
A harmonic oscillator in the Secondary Coil circuit can be “pushed” by the Pulse in the Primary Coil circuit to lead out electromagnetic energy.
Is that a good conceptual picture for understanding?
ltseung888
Quote from: Bruce_TPU on March 11, 2010, 02:53:27 PM
Yes he is a great guy.  And he has experimented with other loads besides A.  Beware of making assumptions.  About people and devices.  Have you seen the magnacoaster info work?  Just because you see a patent pending does not mean that it works.  Another assumption.  There seems to be a lot of them in this thread.  Sorry, but just how I see it.
Have a great day,
Bruce
Thank you for pointing out some assumptions.  In the research area, it is sometimes necessary to make assumptions to cut down the various possible approaches.
Rasa has ordered a unit from Magnacoaster.  I shall have a chance to directly work with that unit.
Theoretically, it should work.  The videos showed that it was working.  The Tong Wheel definitely works and is available for double checking and verification in Hong Kong.  A small version is in my bedroom.  The technique is Pulsed DC to lead-out electromagnetic energy.  The inspiration of FLEET was - can Pulsed DC go through a transformer?
Once the answer was a confirmed experimental yes, there were no more doubts.  The rest is engineering. (Or product production)
ltseung888
Quote from: Paul-R on March 11, 2010, 05:21:42 AM
Thank you for your information again.  I now found a thread in this forum:
http://www.overunity.com/index.php?topic=8289.0
The focus should now be - build the HK$1,000 products.  PLAN FOR a fleet of FLEET products to come out.  The first chance is with the 600 inventors at the Hong Kong Invention Association meeting on March 21, 2010.  The second chance is with Hangzhou.
The third is to pump the information on the Internet and see who can pick it up.  (Sowing Seeds as in the Bible!)  The World will benefit.
