Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 77 Guests are viewing this topic.
ltseung888
Quote from: mscoffman on October 09, 2010, 11:54:57 AM
Power, based on Peak-to-Peak?  Error...Will Ronbinson!  The emperor
has no clothes.  Rectify the AC to DC and filter, then pick the appropriate
load, then measure the power. Or
Measuring AC power;
Fourier decomposition of voltage signal to sine waveforms
Fourier decomposition of current signal to sine waveforms using
the same frequency decomposition as used with voltage.
Take into account phase shift between voltage and current
in decomposed waveforms. LRC
Integrate power in each decomposed frequency band to total.
Calculate error bars.
Done.
:S:MarkSCoffman
Dear MarkSCoffman,
The Power Source seen from the outside is the AA battery.  You would expect to see steady DC voltage when you measure the voltage across the battery.  If you do the experiment, you will find that the waveform is NOT DC.  The battery must be considered as part of the “resonance” circuit.
Both the Input and Output are NOT AC power.  The waveform as seen on the oscilloscope indicated some type of pulsing â€" not a single frequency.
According to the professors at the many Universities (in Hong Kong, China and USA), the correct academic method to truly measure power in such an environment is:
1.   Use the Oscilloscope to measure the Instantaneous Voltage of the Source (e.g. across the battery) using Channel 1.
2.   Use a 1 ohm resistor as a shunt to measure the instantaneous Current (the instantaneous voltage across the resistor) using Channel 2.
3.   Use the multiply function within the oscilloscope to get the instantaneous Power.
4.   Integrate the area under the Power Curve to get the Energy over the chosen time period.
Are you disputing the above measurement technique from all the established academic authorities???
ltseung888
Quote from: rave154 on October 09, 2010, 03:33:04 PM
mscoffman,
i suggested this to Tseung a while back.....his reply was exactly what i ( & i dare say others ) expected.. it was ..."if we add extra components then it will spoil the (magic) resonance effect and no OU is produced".
also, dont mention phase angles between voltage & current to him, it will only confuse him further. lol
Dear rave154,
Please understand that if you have the waveforms of the instantaneous Voltage and the instantaneous current curves, you do not need to worry about the phase angle.  You can get the instantaneous power via their products.
The Steorn forum had pages of discussion on that.  You can also consult your electrical engineering professors.
FatBird
Lawrence,
Thank you for sharing your work and GREAT Photos.  It is really nice to see electronic and classroom photos from the other side of the world.
We would REALLY APPRECIATE it if you could PLEASE POST a schematic or wiring diagram.
Thank you very much sir.
ltseung888
Quote from: FatBird on October 09, 2010, 07:56:26 PM
Lawrence,
Here are some more photos to share.
The most successful part of the Workshop is that some HKU professors and students can produce working FLEET prototypes themselves.
A senior professor said, "We are afraid to teach Lead-out energy now.  But we are not afraid to discuss it behind closed doors.  We are discussing 'killer applications' that will convince the World without the need for the scientific waveforms."
Another comment: "Now that we can produce the HK$20 Fleet prototypes ourselves, you can be assured of vigorous reseach in Hong Kong and China on Lead-out energy.  Once the Official Reports and Papers come out, you will not worry about Government support.  The Industrialists will follow."
ltseung888
The task now is to bring at least 6 working FLEET prototypes that can demonstrate overunity to USA before end of Oct.
The next task is to train the USA students at the top Universities so that they can build the FLEET prototypes themselves.
With dozens or thousands of HK$20 FLEET prototypes that can verify Lead-out energy, there can be no suppression.  The World will benefit.
Stefan will get his FLEET after the University verifications.  The overunity prize money should go to gadgetmail.
Is this the path laid out by the Almighty???
