Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
ramset
Mags
You got a post card, I'm jealous!
Very Handsome family Tito has there!
Shouldn't the little girl be Green?
Well maybe just a relative!
You mention Gold   I always wonder about gold plating a "Collector"
For added harvesting?
If you wanna try this PM me and I'll send you a "KIT"
Open also to any other serious experimenters here!
If nothing else we could gold plate one of Tito's teeth!
Chet
Thanks Grandma
delboy
Quote from: baroutologos on March 13, 2010, 06:16:06 PM
Shrimps and whips!  ;D
Lets people get engineering and calculate some rough figures about Tesla's high inductunce. I have the question how much is the high inductunce anyway?
resonant frequency: Because the L2 coil that must run on resonance for best results is a small coil (Fig2), i assume it will have a natural resonant frequency of some 600Khz. Using a Tesla coil calculator with the following data:
L2 coil diameter: 5 inch
Length: 10 inch
wire: 24awg
we have some 450 turns with an inductunce of 11m H with a natural freq of 600Khz
I proceed. if the primary is:
L1 diamter : 5 inch, 4 turns and 0.25 inch diameter will give some 5uH or less inductunce.
This will require a 14-15 nF capacitor to be charged 200 times per sec.
And that will be all of Baroutologos' calculations based on the Ozone patent :) :) :)
Now you tell me where the OU comes into the picture
High inductance for max 200 makes/breaks will be any value bigger than 200mH, for example you take 500mH (secondar from some transformator). Now combining that value with your 200 makes/breaks gives the value of primary condenser of 1uF to 2uF !
And why is your L2 so small? Try bigger diameter and lower frequency, for example 50 inch diameter and 100kHz !?
OU comes into the picture when you get enogh high V/m on output at not too high frequency! That way energy will not be radiated in space, and you can pick up with one-wire receiver as much as there is reactive energy ;)
baroutologos
Something irrelevant somewhat to this thread... but interesting to dell boy. :)
Today i was reviewing a book i purchased about Tesla and it suggested the patent 1,119,732 as the one used for energy transfer via electric ripples in earth at long distances plus some other arcane uses the author suggested :)
I printed that patent and studied with a new eye, after reading Colorado Spring notes.
I dare to say this patent, being of the last ones Tesla issued, includes the essence of Colorado Spring notes.
It has all the methodology.
*Tight inductive coupling between a large radius primary/secondary for increased efficiency,
*on top of that an almost unclouped and free oscillating coil (xtra coil may be said) that has .
*a hood for dealing with sparks,
*an elevated terminal (since Tesla discovered the one terminal capacitance of his coils is raised by 10% per foot)
*top terminal with the small hemispheres closely placed for increaseing one terminal capacitance.
Notein the final design, Tesla suggests a small radius xtra coil for free oscillations and a large radius secondary (tightly coupled with primary) for good efficiency i guess.
I have not seen anyone building such Tesla coil, even in miniaturization.
I guess i should give it a go ;)
@Tito,
I suppose you are finilizing the promised device... right?
