Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
Magluvin
Just saw the vid on the other thread you are on, it doesnt seem like it has any solid freq to work. Actually it seems like if it were a bit higher freq, the lights would be more steady.
coil tails, could it be that simple?  =]
http://www.youtube.com/watch?v=VZtvJy3cRzo
Mags
baroutologos
Acoording to the other thread, i have expressed there my views. The system behaves as cap-discharge magnificator (assuming its true) rather than resonator. The lamps flicker more or less in relation to spark-gap.
That's my oppinion anyway
Magluvin
I agree totally. I imagine that there could be a solid freq that would really make it sing, but pulse for pulse, thats a great gig.
I am going to cut up a piece of pvc and wind me a coil with some space and make a bunch of taps. This will be fun to try.
Mags
forest
Thats Tesla igniter patent  ;D Look how fast microwave cap is discharged and recharged. Pure potential.
Magluvin
Well Forest, it looks like we have many good ingredients to work with now.
So first, we are able to produce a high tension source with a pulsing circuit, regardless if resonance, and discharge the cap into a coil, any coil, but this coil we give it a tail. Not anything different really from Kapanadze just a lower range of power, but the amplifying effects should work regardless, 1 pulse at a time, or at a freq that works best for each variation.
But as to what and where it it happening, theorys...
First, if we send energy to the coil, and current goes in one way and then it comes back out in the opposite direction, and if we make it possible for all of the collapse to be maximally absorbed to the output, either by load or step up to recharge loop,  then we should have virtually no ring left. Up then down, it sits and waits till the next incoming pulse. So there will be a freq that will give minimum off time and should be able to work on that freq and down.
So we will call the TC  Tail Coil   and divide that into the Dog and the Tail, the Dog being the portion of the coil that the pulse is sent across, and the tail wags.
If we pulse the dog, what should we expect to begin with, does it mater the polarity of the pulse to the dog.
What happens to the pulse in the coil while being pulsed, after the input pulse dissipates what happens in the coil to give us more?
Ill finish with a thought then I gota git till next time.
This seems contrary to Don Smith as in he says the primary should be in the middle of the secondary to increase the volts and amps. Unless Dons coils are some way connected at the ends and the tail is in the dog. lol  Well there may be some experiments that that coils can be inter woven and improve the effect. Bifi? Put them in seies and pulse just 1?  Maybe.  Seems to have the qualities for the job.
But we are seeing a few TC projects gong on out there.
Come here Fido, I got my meter, time to measure your tail.   =]
Mags
