LaFonte Group can turn off permanent magnet without work
Started by Paul-R, March 03, 2010, 06:31:34 AM
LarryC
Quote from: wattsup on April 07, 2010, 02:54:12 PM
If your stator has many individual winds, I suggest you put a diode after each one individually, then put them in parallel, and not, in parrallel then all on one diode. This will cut out themutual drag that is devellopped and shared amonst the coils. This way, once the magnet passes the coil, the energy is taken out and cannot re-effect the coil.
Not sure what unit you are talking about. My current unit is shown in reply 99. I'm using the primary on the H cut transformer. There is several secondaries, but the primary has the best windings for the output. Use of any of the secondaries just reduces the power in the primary in an attempt to balance.
If you are talking about the concept that I showed in reply 105 that you quoted, then I don't have it built and will probably not be able to build it. The arc magnets are available, but the rest of unit would be very difficult to build.
I am including another picture of the reply 105 concept with more information to clear up the concept. The red is the flux, yellow is the stator slots, and blue is the pole. The drawing shows three positions of the rotor and the flux at each. Sorry, no simulator, but hoping Butch would show. Large commercial generator use many rows of coils, this concept, if it works, would allow that to happen with as many rows as needed.
Regards, Larry
Tito L. Oracion
Quote from: wozlzl on April 07, 2010, 09:21:41 PM
Looking at wow power leveling a girl from a distance wow power leveling intently and not looking away aion power level even when she sees you can be very sexy and thrilling aion powerleveling to her. It tells her aion powerleveling that you desire her and that you cheap aion power leveling are so confident that you wow power leveling will prevail. Keeping a steady gaze during a conversation tells her that you are interested in what she cheap wow gold is saying and that you are listening to her. Because of this, you will be perceived by her to be honest and sincere.
hey WOW, you power your leveling wow gold. lol  ;D
Butch LaFonte
gotoluc
WoW Butch! looks great ;)
Just drop in the coils and it's spin time ;D
Really wishing you great results
Thanks for taking the time to share your work
Luc
hartiberlin
Hi Butch and Mark,
looks great.
What material did you use for the outer rod,
there where the coils will sit ?
Is this pure Iron ?
Hopefully the eddy currents will not be too big..
Regards, Stefan.
