LaFonte Group can turn off permanent magnet without work
Started by Paul-R, March 03, 2010, 06:31:34 AM
0 Members and 18 Guests are viewing this topic.
DreamThinkBuild
Great work Butch LaFonte & Group,
Quote"It turns as though there were no power be supplied to the coils."
The implications are staggering. How many magnets and coils could one shaft drive per horsepower? If you make the spaces between the 2 part ring wider can you generate a high current pulse in the output coil? Much like an impulse generator?
hartiberlin
Hi Butch,
get yourself Ironoxid from a painter´s shop.
It is a dark black powder, which is pretty magnetic , BUT
non conducting ! Mix this together with water and an acrylic binder
you also get at a painter´s utility shop or an epoxy glue and you have the
best selfmade ferrite core you can build
which will have almost no eddy current losses...
Hope this helps.
Regards, Stefan.
Butch LaFonte
I can't answer that question to honest with you at this time. We still have a lot of testing to go, but I can say that with no eddy current drag and no aerodynamic drag to speak of on the rotor, bearing drag is the only loss with respect to rotor operation. It's output should be limited only by the strength of the materials in the rotor to with stand rotational forces. Yes the system can produce AC pulses, but the current output will vary with the type of load, resistive or capacitive or a combination. Electronics will come into play to get the most out of it then.
Hope I understood your question and answered it for you.
Butch
Butch LaFonte
Hi Butch,
Hope this helps.
Regards, Stefan.
Thanks Stefan, that will move this project ahead. We were almost at a stand still.
Thanks again,
Butch
hartiberlin
Great,
yes, you can get this powder in shops were they sell selfmixable
colors for painters.
There they have many different color powders and also this
nice IronOxid powder.
You can probably also get it cheaper directly from
any chemical supply distributor.
See also:
http://en.wikipedia.org/wiki/Magnetite
and
http://en.wikipedia.org/wiki/Iron%28II,III%29_oxide
but in my case of the color pigment it is non conductive..
You can probably also get it from black sand at the beach for
free.,
Just go with a big sized neodym magnet to the beach and try to
pick it up there via the magnet.
Hope this helps.
Regards, Stefan.
