Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
Bertoa
Looking near to Yildiz claims in the patent, he writes about an inner stator, the rotor as a hollow cylinder, and an outer stator. In his drawings you can see this principle in fig.11 in fig.17a and very clear in fig.21 and 22. I think that is the crux. There is a certain order of magnets on all of those parts. Using an hollow rotor and within a core stator is genial. It makes as if the rotor runs on magnetic bearings. Fig. 22 shows how this construction works as a tri-force rotor and maybe as a Halbach array. Fig. 21 explains more about the set up of the magnets and the polarization.
His approach in ordering the magnets is for sure very original.
gravityblock
The spectral analysis done by zerotensor is a good indicator of the RPM decreasing during the test.  This is in-line with the volt and amp measurements in Table 1 decreasing, from a test of an earlier prototype from Yildiz in 2005, http://www.rexresearch.com/yildiz/yildiz.htm
GB
Low-Q
Except there is a sudden change in rpm at the video break. Before and after the rpm are stable...
Rapadura
Quote from: Gwandau on April 23, 2010, 04:43:40 PM
It's ten axial rows of magnets placed in a hexagonal pattern with a central magnet in each hexagon. This pattern results in the typical
Perendev displacement setting of 20 degrees. This is a Perendev motor!
If it's a Perendev, then we are loosing our time. Perendev is a scam and the scammer  was arrested this week.
I hope it's not a Perendev. But i'm starting to think that it's a hoax... If it was genuine, the inventor should already had made a definitive demonstration, lasting for hours, not minutes.
Omnibus
Quote from: Rapadura on April 23, 2010, 08:16:12 PM
Don't be too fast. We can't be so sure what the actual situation around Mike Brady is. That whole arrest thing is about angry investors and the fact that he hasn't delivered on time may be due to various excusable reasons. If delays in delivery are to lead to arrests then those with the Tokamak or the ones with the 5 billion dollar laser fusion delaying the delivery for years if not decades should be arrested way before Mike Brady. The problem the likes of Brady and Yilmaz have is that they dream of fortune from their creation which will never come to life because an OU machine is the most anti-business device known to man. Companies would be out their minds to invest in it even if they convince themselves beyon doubt that it is real. What these people should do is go out of their way to have thousands replicate their machine around the world as promptly as possible. That's the only way they can protect themselves as well as improve their financial state.
