Self running coil?
Started by gotoluc, March 13, 2010, 12:40:57 AM
gotoluc
Quote from: HarryV on March 17, 2010, 10:33:46 PM
Here it is as a jpg and pdf
Let me know if it is ok.
Harry
Excellent work Harry ;)
Thank you very much for the great job :)
I'm looking it over and will let you know of any add ons or changes.
Luc
gotoluc
Okay Harry,
here is the add on:
Add (With magnet aprox. 1/8" air gap) and (With magnet aprox. 1/16" air gap) See attached
And like Mags says, both coil sides start and end the same way. This maybe the most important point as so far this is the only coil that works.
Thanks
Luc
mrock
NextGen67
Quote from: gotoluc on March 17, 2010, 11:17:33 PM
Okay Harry,
here is the add on:
Thanks
Luc
And the 24 mm should be .24 mm? (actually .255 including dielectric layer?).
@Luc, could you maybe find out the fabric/type of the core, and maybe give a 2 digit value for the coil resistance e.g: 6.9x Ohm.
It's a very clean and simple circuit !
NextGen67
NextGen67
@Luc,
You mention in the video that while the Cap is charging, you constantly need to re-adjust the frequency of the generator slightly. That means the Cap is influencing the coil behavior... Is there a way to collect the energy in the Cap, but exclude the cap from the from the rest of the circuit? Or just try to place the cap (or another one) at a different place in the circuit and by such avoid any possible leaking at all ?  Maybe a simple diode could allow a one way only energy direction to the Cap.
NextGen67
