Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
innovation_station
Quote from: Bruce_TPU on May 04, 2010, 07:52:46 AM
Hey guys,
I appreciate the concern, but it is "just" money.  Worst case, and I end up selling a bunch of magnets on ebay.  I have spent so much money on OU research that has not worked, but I know this will produce power.  Will it be OU?  There is no way of knowing until I try.
Electromagnets require electricity.  Not the route to OU in my humble opinion for this build.  These magnets are powerful with seventy five pounds of holding force, each.  I have no intention of allowing them to come together.  But, if they do, I will have purchased a magnet seperator, from K & J Magnetics.
So, onward we go!  When I think of Marco, Giantkiller and Ironhead, who have spent considerable fortunes building, not to mention Moby, it is a drop in the bucket.
Cheers,
Bruce
bruce im glad you have persued your own path .. this is infact what it is all about .. its a big sand box ..
you have named many  people i enjoy reading there work .. from time to time ! and to each much respect is sent !
i have been able to get large neos .. for 10 bucks each .. 200 lb pull  1"x 2"  i have 10 .. for a high torque pulse motor i ever get that one done ....  lol
i cant be sure where they came from any more .. some where in the US
ist
Have been out of the loop in the homopolar area but what you are doing is excellent work. I have never investigated pancake coils too deeply in HPG's but with my gained knowledge they COULD produce a higher voltage than a plane disc. I put that in capitals because it's a very important assumption, because if the voltage is higher you can instantly build a zero back torque generator.
I just quickly went over this thread but I can't say I fully understand the setup.
Bruce_TPU
Quote from: broli on May 05, 2010, 07:20:49 PM
Hi broli,
The set up is simple and straightforward.  Instead of using 10" single magnets at the cost of thousands, I am building a "virtual" 10" magnet, by using many 1"x1" axial N52 magnets.  All poles will be facing in the same direction, and magnets held by very THIN steel.  This will again be duplicated for the second 10" "virtual" magnet.
Next, I will have five pancake coils, each made of 40 feet of 12 awg stranded (42 strands) wire.  Each pancake coil is the Tesla bifilar coil.  Between each set of coils is a thin Iron oxide coating, to amplify the field lines.  It is very uniqe and my own ideas and creation, if I say so... lol
The power will be taken off with brushes.
My bearings will be magnetic and as close to friction free as possible.
What to drive it with, that is still a question.  Perhaps a very small hobby motor and pulley transmission.  Something very low power.  So, that is the set up!
Cheers,
Bruce
Quote from: Bruce_TPU on May 05, 2010, 07:50:21 PM
Hi broli,
Cheers,
Bruce
Ok then I had something else in mind. I made a drawing of what I thought you were doing. No need for brushes, of course that's a dangerous slope. Basically if current flows you win, if it doesn't you lose  ;) .
Bruce_TPU
Hi Broli,
Your picture is close!  take away the disc all together, disconnect any electrical connection to the magnets (for now!) and sandwich 5 of the bifilar tesla pancakes together, with a thin coating of black iron oxide (non conductive) between them, and you will have my initial set up, exactly!
Cheers,
Bruce
