Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
void109
Just wanted to drop a note on the frictionless bearing set up, I've been putting together an HPG for awhile now, I'm using two 3" OD 1" ID 1/2" thick neos, and using those as well to levitate the rotor (which is on a 1" thick copper bar).  It's all quite heavy but levitates just fine.  I'm using 2" x .5" neo cylinders to support the shaft.
Its not done yet, I want to put some simple circuitry and reed switches attached to the shaft itself, to use the DC current produced to pulse coils affixed to the shaft to repel against a stationary neo magnet centered below it.  Just want to see if the current produced is enough to drive it (and if and how much magnetic drag the device experiences just from the current generation as well as magnetic levitation.
innovation_station
that sounds so verry kool your device ...
how ever reeds will burn out !
the power produced is extream !
i took 2 speeker magnets forced them togather wedged an alum plate inbetween them then spun it
holding the wires of my multi meter in my fingers  well they got burnt and the drill went 1 reveloution
and were there sparks or were there  sparks ... lol
ist!
this goes back years when i released the device PUBLIC !  i have a drawing round this site some where
Bruce_TPU
Good evening ALL,
Well, I took the plunge tonight, and ordered my first 6 magnets!  Of course, I will need many, many more.  I used a discount code, and also received a discount for buying 5 of them.
This will get me started, as far as cutting the foam, designing the pvc magnet holders I have in mind, etc.  The goal is to NOT have to glue them.  In my mind it works, I just have to see if it plays out in real life.
Pics of the ones I ordered and info. below.
@ void109
I would be interested in seeing a picture of your set up.  Many thanks!
Cheers,
Bruce
PYRODIN123321
Hi, I read that stuff on Tesla posted in this thread the other day, got me thinking, anybody know if this has been done before?
I was thinking it might work, what if the magnet is completley surrounded by wire and mounted on an axle the current all going the same way {see picture}
I might mess with it, looks pretty easy to build....
Peace.
Bruce_TPU
Quote from: PYRODIN123321 on May 07, 2010, 12:55:28 PM
Try it.  It should work.  (work defined as showing an electrical output)  Just the more wire, and larger size, the better, I would surmise....
Cheers,
Bruce
