Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Sprocket
Quote from: mscoffman on May 11, 2010, 11:55:15 AM
Three things;
(a) you need a uniform magnetic field covering the whole coil disk.
(b) The brushes need to be on the periphery the coils.
(c) The green wire is crossing the magnetic field to get to the
  outside of the magnet. This is a no-no. It should go up through
  the center of the coil.
If you fix these things and get some iron wire used in fastening
air conduits inside of buildings and insulate it, you might also try
a coil made from that.
:S:MarkSCoffman
Hi.  '(a)' I was aware of, the pancake was pre-made but I was planning to encircle the big neo with little 15mm ones.  '(b)' I knew about, or should I say I knew others did it this way - I just thought it didn't matter that much and my way was better!  Obviously not!!! :D  Still don't understand why! '(c)' makes more sense though.  Thanks for the info!
See, there is a reason that I still pay utility bills! :D
Bruce_TPU
Hi Mark,
I hope that you are wrong on (b).  That is not my set up for my initial test.  ;)
For your (c), I agree, but again in my case, I will not have it "radially" but wound in pancake style to reach my brushes.  We will see..  As my initial setup has no hole through the large 10" magnets, and I am winding all ten (10) leads from the center out, pancake style to the outside.
But, the design is flexible if it doesn't produce as it should.  I feel confident in producing some good amount of power...
Good evening all,
My first little group of six magnets arrived... and MY OH MY, these N52 are STRONG!  Taking extra precautions when working with them.  They are the perfect magnets for this build, IMHO.
Cheers,
Bruce
mscoffman
Quote from: Bruce_TPU on May 11, 2010, 08:42:12 PM
Hi Mark,
Bruce
@Bruce
I hope you'll take comfort in knowing that no matter what happens...
I can give an explaination!  ::)  ...Good Luck!
Bruce_TPU
Quote from: mscoffman on May 12, 2010, 07:44:56 PM
@Bruce
LOL  That was funny, Mark!   ;D  Let's hope that the explanation will be of it "working"... LOL
Thanks for the best wishes!
Teutates
Bruce,
If copper fails you might give silver a try...  I've been doing some experiments using 99.999% pure silver wire and seeing results that exceed (slightly) what I see with copper.  Plan on posting my results at a later date.
Steve
