Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Happy Friday ALL,
Tomorrow I will begin to machine down my magnet holders.  I found some perfect inner diameter couplings for the job, just need to trim the length and sand out the inner ridge.  Once this is accomplished, I will place my first magnet on my metal plate, dead on in the center.  Then I will place a second magnet, same poles facing the plate, in it's holder, onto the metal plate and see how close I can slide it, to the center one, seeing how they will be in repulsion.  Next, I will measure this distance with a caliper, and record it.  The next step is to cut my foam with the holes of the proper size and then drop this also, onto the metal plate.
Also, this weekend, if time allows, I will extend my "ends" of the tesla bifilar pancake coils and then glue and wrap them into their proper configuration.  I have already picked up the wire for this.
Of course I will post pictures as the progress continues.   ;)
Cheers,
Bruce
Bruce_TPU
Stefan, if you could please erase the spam in the above post.
Thank you,
Bruce
Bruce_TPU
Happy Saturday ALL,
I am making some good progress this morning!  I have machined out all of the inner ledges of the couplers and then cut each to the proper length.  After, each was sanded.
Next, I did my test with two magnets, both with same poles facing down.  I pushed them together very close and marked the distance.  Now I am working on cutting out the foam, and will post pictures of that later.  The N52's are very strong, but I am getting the hang of working with them, and how to seperate them, without crushing a finger...
I could use some ideas for type of glue or epoxy to hold my pvc magnet holders to he metal disc.  I am thinking either JB Weld, E6000, or Super Glue.  Any better ideas, please don't hesitate to post.  Thanks!
The work in progress below in pictures...
Cheers,
Bruce
Bruce_TPU
Hello again ALL,
Well, I am on a roll, and have completed the insertion of my first six magnet holders into the foam.  Now I need to purchase many more couplers and start again.  But now I feel like I have a good system going and it is easy and fast.  And having the distance between magnets is of course key!
Cheers,
Bruce
Bruce_TPU
Hello ALL,
Doing a lot more work, while saving for my next round of magnets.  I have cut all of the 1" holes for this rotor, and will next be machining the insides of my new couplers, and trimming them down to size as I did with the others.  I still need more.
I also have room out towards the edge, for 12 more magnets, but not 1 inchers.  Rather, 1/2" diameter, 1" deep.  I will be finding the couplers for those next.  This is not a "fast" build but it will be steady.  Please remember, if my Tesla Bifilar Pancake Coils do not work well, I have MANY other options to try, to "sandwich" between my very large magnets.
Cheers,
Bruce
