Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Quote from: Airstriker on March 22, 2010, 09:10:51 AM
If you are not familiar with unipolar generator you should read also this:
http://www.physics.umd.edu/lecdem/outreach/QOTW/arch11/q218unipolar.pdf
What you will find interesting there is the fact, that it works by just having a rotating magnet only. No copper disc needed. But still Lenz law applies. So I'm no really sure your idea with pancake coil will work. But give it a try if you like.
Hi Airstriker,
A very interesting PDF you posted!  It also confirms a conversation that I had with a friend, last night.  It was mentioned that if a bulb is attached to a copper plate (coil in my case) to rotate with said plate, it will not light!  It is in the wrong "time reference frame".  It will only produce a flow of electrons that are usable, if another "reference frame" (brushes, etc, not moving..) are drawing off the current stream.
I have been doing some thought experiments and think that perhaps "canceling" Lenz is not what Tesla was after with his unipolar generator, but rather, making Lenz law work in his favor... The more I think on this, the more likely it seems.
But how could he do this, one might ask.  Well, I really think I will find my experiments will bear out the following...That a Tesla pancake coil, laid in the proper direction, and spun (CCW) that the potential should travel from the inside to the outside following the spirals.  This Lenz production of magnetic fields could then actually "add" to the spin of the unipolar generator, perhaps, as crazy as it sounds to the point of self excitation.  (wouldn't that be a hoot!  LOL)
I found on page 10 of Tesla's Unipolar Generator Notes, an interesting passage that denotes the exact description as I gave above.  Tesla's words are now reinforcing this thought experiment.  (words pictured below)
On another note, I think that I have come up with three differant ideas for taking power off of the coil(s)  One way, I really like is a bit ingenious if I say so myself.  And one way is a bit old fashioned, but will work.  And the last way is not my own original idea, but is unique and would make an interesting experiment.  All Three pictured below.
Idea 3 is interesting because the bearings can be rotates as a homopolar generator also...and may add to the field?  Experimentation will tell, but just thought ideas for now to rough in my designs, and ideas.
Cheers,
Bruce
Airstriker
The idea 2 doesn't really make much sense as you will have the same potential on all of the brushes (all on top ring and all on lower ring) and you will end up only with additional friction because of the additional brushes.
gravityblock
The pancake coil or the division of the disc into spirals is only needed if the magnetic field of the magnets do not completely cover the entire disc.  In Tesla's own words on page A-23 of http://www.andrijar.com/teslahom/teslahom.pdf he says, "If the poles do not cover the disc completely on both sides, then, of course, unless the disc be properly subdivided, the machine will be very inefficient".
Look at figure 1, 2, and 3 while taking note how the poles of the magnets being illustrated do not cover the entire disc.  He's talking about Eddy currents here, because the poles aren't covering the entire disc between the rim and the axis.  If a copper disc is sandwiched between two axially magnetized magnets, and the copper disc is the same diameter of the magnets so the poles cover the entire disc, then the Eddy currents Tesla is referring to is no longer an issue and we don't need to worry about properly subdividing the disc or using a pancake coil.
He then, goes on and talks about how the Eddy currents could demagnetize the field.  We don't have this problem today, because our magnets are so much superior to the magnets of his day.  Also, to think that the Eddy currents could magnetize and re-enforce the field to self-excite the dynamo, especially after eliminating these Eddy currents, by subdividing the disc, using a pancake coil, or having the disc and magnets to be of the same diameter is total nonsense.
I do believe the HPG has OU properties, but we must eliminate the counter torque.  Increasing the radii of the disc and magnets will increase the output power to the 4th power while the input power only increases to the square thereof.  The problem is the counter torque also increases proportionally.  The Eddy currents is not the counter torque we need to overcome.  The counter torque we need to overcome is the HPG also acts as a HPM that works against the rotation of the system, which kills the OU properties.  Defeating Lenz is a must in any system.  There is an easy way to test this.  If it can run as a generator, but can't run as a motor.....then we have success.
GB
Paul-R
Quote from: Airstriker on March 23, 2010, 11:40:54 AM
I think the idea of multiple brushes is to share out the current
which can be exceptionally high, the voltage being very low.
gravityblock
Quote from: Paul-R on March 23, 2010, 08:02:30 PM
Having multiple brushes will increase the current.  We don't won't this, since the system is already a low voltage, high current system due to it having a low resistance.  When you add brushes, then you are adding more paths for the current to flow, which will lower the resistance even further in the system.
In a pancake coil, you only need one brush around the entire rim and an additional brush for the axis.  The brush around the entire rim and axis will always provide a contact point for the pancake coil, but it must be looked at as only being one large brush instead of having multiple brushes (the ends of the pancake coil will only be making contact with the brush at only one specific point at any given time).
There is only one path for the current to flow in a pancake coil.  In a solid disc, then adding additional brushes will add additional paths for the current to flow and will increase the current.
GB
