Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
sparks
  On the motor generator thing I remember seeing a guy doit but the generator was mounted on a disk.  The countertorque on the generator stator was transferred to the drive mechanism using pulleys.  The Earth transfers some of its angular momentum to the moons orbital momentum.  This slows the rotation of the Earth and increases the angular velocity of the moon.   This causes the moons orbit to become more eliptical.  Someday it might just keep on trucking and never come back.  I was dynamometer testing a small 1/6 hp fan motor one day. I didnt bother bolting it down just chucked it and grabbed onto the stator.  My guy was at the load control smiling.  I said give it to it.  He loaded her down.  (The load is created by spinning a large steel disc through electromagnets causing eddy currents by the way)  It took considerable energy on my part to hold onto the stator.  After about 15 seconds I had enough and my guy turned the switch off still smiling.  If the stator I was grabbing had a pulley on it driving a generator load I dont think I would have broken a sweat.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
mscoffman
Quote from: Bruce_TPU on April 15, 2010, 09:27:08 PM
I have also come to the conclusion that I will have painted, all of my pieces.  I know someone who paint's cars and will take it to them for a proffessional job.  This will make it non-electrically conductive and avoid eddy currents of any kind.  I will have the shaft and all metal pieces painted.
Taken out of context this text reads strangely... It should say:
"painting pieces will eliminate any eddy currents flowing between
the pieces". Painting won't paticularly reduce eddy currents flowing
inside unitary pieces of metal. In fact the homopolar generator disk
is one giant interrupted eddy current.
:S:MarkSCoffman
gravityblock
Quote from: mscoffman on April 16, 2010, 12:01:26 PM
inside unitary pieces of metal. In fact the homopolar generator disk is one giant interrupted eddy current.
:S:MarkSCoffman
I don't agree with this.  If the metal disc doesn't have a return path and is electrically isolated from the copper disc or coil which you will be drawing current from, then a static electric field is setup on the metal disc itself (the separated charges on the metal disc will have no where to go, due to no external circuit to complete a closed circuit).  Also, as long as the magnetic field is completely covering the conductive copper disc, then this eliminates most of the eddy currents.  Eddy currents are not a problem in the HPG.
GB
Bruce_TPU
:S:MarkSCoffman
Good thing I am not using a "generator disk" then isn't it?  LOL
Back track and read the parts that I wrote...correctly, please.   ;)
Cheers,
Bruce
Bruce_TPU
Happy Saturday, ALL,
I feel as if I have made good progress today!  I did the painting myself and also designed and built the B.R.U.N.G. output stage, which is now prepared for the future brushes and mounted on it's shaft.  This part was critical and took a great deal of work but alas it has turned out just fine...
There is a nylon tube grommet glued inside, to keep the wires from contact with the shaft and to hold the output stage to the shaft.  The output stage IS removable from the shaft, if I need to change this shaft to a different length.
Cheers,
Bruce
