Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Quote from: gravityblock on April 20, 2010, 12:02:16 AM
@Bruce and All:
An analysis of the inventions intended by Tesla, on the reference you posted, is found in "The Second Law Thermodynamics and Tesla's Fuelless Generator", by Oliver Nichelson, http://www.scribd.com/doc/30212011/Tesla-s-Fuelless-Generator
I find it interesting how the analysis by Nichelson, talks about the displacement current.  I have been studying the displacement current from the same author of the "Paradox 2 experiment".  In this paper, on the "Maxwell's Displacement Current", http://www.distinti.com/docs/maxdispcur.pdf , there is an experiment to test the validity of Maxwell’s Displacement current term.  The experiment showed that there is no magnetic field generated by the displacement current (I hope you study this experiment).  Displacement current is simply another way to say capacitive coupling.
I hope this post isn't going off-topic, but I think the information on the displacement current along with the analysis of Tesla's document, by Nichelson, could be helpful.
GB
Hi Nightstriker,
Page 6 of the .pdf by Oliver Nichelson contains the graph and explanation that I had mentioned before, concerning the 900% voltage increase found in a Tesla Bifilar Pancake coil, vs. what it should be.
Hi GB,
A great find on the entire .pdf!!  Displacement current within the unipolar generator seems to fit everything described.  I really think that combining the bifilar pancake with this Machine will be spectacular!  Funny how differant people come to similar conclusions in totally differant thought process'.  But unlike the author (that I know of!) I am building one.   ;)
Cheers,
Bruce
wings
Bruce_TPU
Good evening ALL,
GB, Wings and others have posted some very good links. Thank you guys.
I have wound the first of six, bifilar Tesla pancake coils....It turned out awesome!
I learned so much from the other pancake, and this time I used hot glue to wind it, as well as my bifilar winding jig that I built.  I am going to coat it tomorrow on one side with a very thin coat of fiberglass.  It will make it very durable.  I was not real happy with the laquer.  And then a coat of iron oxide on one side.
I am thinking seriously, that to keep the others stacked one on top of the other, and keep to my 1.25" limit between my giant magnets, that I will take the two center wires, and thread them through the next core, etc, until all six are stacked, and then wire the one outer edge to the one inner edge.  As long as I have them tagged, I think this will work.  I will then only have the space of one wires width for all of the ends, vs. three or four times that width.  Distance is very important, because distance from X, the center point between the two magnets in attraction, will have the weakest flux field, increase the distance very much and it lowers it...drastically.  I had found a magnetic calculator.  Thoughts on my stacking idea?
Cheers,
Bruce
Bruce_TPU
Good evening to ALL,
I have put a very thin coat of fiberglass on top of my bifilar coil.  It is now very solid!  Tomorrow, I coat the otherside with black iron oxide, and start in on a second coil.
The thickness of this first coil is only 1/8", which would mean, that if I stack them as I suggested in the above post, I should be able to actually stack 8 Tesla bifilar pancake coils in my 1 inch space.  That would give me a total of 320 feet of 12 awg stranded, at 42 strands, gives the equivellent of 13,440 feet of wire to interact with the magnetic flux field.  I have drawn a picture below showing only three coils, in case it was difficult to understand what I was describing in my last post.  I drew only three for time constraints.
Cheers,
Bruce
