magnet-gravity wheel
Started by FreeEnergy, March 27, 2006, 11:51:18 PM
hartiberlin
I think it will not work.
You have just drawn the sticky spot.
Why should it turn on, when the magnet has "grabbed" one lever arm ?
FreeEnergy
it has grabbed one lever arm but there are two other levers running free shifting weight to the right side making kinetic energy. if the right side is not heavy enough to break from the sticky spot, then the kinetic energy can be preserved as electric energy with some kind of circuit to turn off the magnetic field so it wont be stuck to the sticky spot.
* the magnet's location varies. would have to try different arrangements to see which is better.
FreeEnergy
yeah ive been studying this wheel for a while now and yeah you are right. it will not work.  :-X
i could be wrong.
Omnibus
Quoteyeah ive been studying this wheel for a while now and yeah you are right. it will not work.  Lips Sealed
i could be wrong.
What made you reach that conclusion?
FreeEnergy
well if anything it just might work with some kind of circuit setup like i mentioned above. only with circuit setup though...im not sure
