magnet-gravity wheel
Started by FreeEnergy, March 27, 2006, 11:51:18 PM
Omnibus
See, the goal is to avoid any external energy input whatsoever. Also, I don't think you should easily give up on this before you at least carry out careful calculations applying the methods of Strength of Materials (the branch of Mechanics civil engineers use the most) or model it with a program that uses these methods to calculate the forces. What we're doing here is just judging by intuition which may be misleading in the long run (both pro and con).
macelyne
I believe that it doesn't work. ( religious argumentation ) :)
FreeEnergy
wheel phases without magnet/circuit
FreeEnergy
please if someone could point me to the right direction for turning on/off magnetic fields using simple circuit setups? i really think this wheel will work with the help of turning on/off magnetic fields.
thanks guys,
FreeEnergy
Quote from: FreeEnergy on March 30, 2006, 01:57:54 AM
it has grabbed one lever arm but there are two other levers running free shifting weight to the right side making kinetic energy. if the right side is not heavy enough to break from the sticky spot, then the kinetic energy can be preserved as electric energy with some kind of circuit to turn off the magnetic field so it wont be stuck to the sticky spot.
* the magnet's location varies. would have to try different arrangements to see which is better.
jake
Once you add the electricity required to make it run, you have (once again) invented the electric motor!
