magnet-gravity wheel
Started by FreeEnergy, March 27, 2006, 11:51:18 PM
FreeEnergy
i guess not? am i right? lol good idea!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
wattsup
Since I was using the same plate lettering as one of the former posts the string connections should
really be from A to B, B to D, D to C and C to A. All four strings would be the same length, that is, the length from the right tip of C to the roller end of A plus about 1/4' more to not stress the system during 75% of a cycle. The distance from the tip end of A to the roller end of B, if B was on the leftwards edge, would be longer, so the string would pull B rightwards. I guess if you started the wheel with B completely rightwards, you would not require the magnet since A would have enough momemtum to tilt the wheel and start C sliding right. This should actually work.
MrMag
Just my two cents but, if you want to use a magnet, could you attach a small ball on the ends of the arms and then set up a smot system instead of the single magnet?
Tim
FreeEnergy
Quote from: MrMag on November 15, 2006, 11:10:04 AM
Tim
i don't see why not. have to test it out.
FreeEnergy
could anyone help me build this in wm2d please?
