magnet-gravity wheel
Started by FreeEnergy, March 27, 2006, 11:51:18 PM
FreeEnergy
i just figured something out today. the smot should only be applied to arm A and not the whole weight of the wheel as shown. this is very important and makes the wheel so much more efficient. this should make OU.
i don't think i have to apply http://www.overunity.com/index.php/topic,2019.0.html to my wheel anymore. will see.
Dingus Mungus
Sounds like a great idea!
If you can get enough rotational force from the smot track to
overcome the wind resistance then you'll have "perpetual motion"...
Till the bearings go out that is.
I noticed that a continuos rotational force of just a few N's could keep it going...
Good Luck,
~Dingus Mungus
FreeEnergy
if the smot is only picking up the weight of arm A this will be over unity i think. at the sticky point you will have twice (arm C and D) the weight of arm A going against the sticky point.
also the magnets would be at attraction mode and not repelling mode. the smot would be at a vertical position. the smot is what tucks arm A in.
FreeEnergy
hope this helps. see previous reply.
Low-Q
I can see the idea of operation when the motor is rotating very slow. What happens when the motor starts to increase rpms? What happens with the time delay in the falling arms caused by the limited acceleration of gravity (9.81ms^2) when it start to spin faster?
Br.
Vidar
