magnet-gravity wheel
Started by FreeEnergy, March 27, 2006, 11:51:18 PM
FreeEnergy
Quote from: CLaNZeR on April 17, 2007, 05:52:14 AM
Just thinking again about the smot.
I was going to use two bar magnets set either side of the metal washers on the up stroke and set them out the same angle as the tradditional smot ramp with a air space either side. North facing in one side and South facing in the other.
I take it this is correct? if not can you expand on what sort of smot you are thinking of.
Sean.
i am not sure what you're saying but this should explain it.
make sure the smot is only strong enough to lift arm A, anymore stronger and it wont work.
FreeEnergy
any news CLaNZeR? are you back? :)
CLaNZeR
Hi
Yep back and usual manic weekend trying to get everything done!
I will find some time this afternoon to get the steel washers attached to the arms and knock up a simple ramp using two magnets and see how it goes, will post the results later.
Sean.
http://www.overunity.org.uk
CLaNZeR
Right had a bit of play with this one and sorry to say I cannot see that she is going to fly.
The main thing is the balance of the arms and the simplest way for me to show this is by doing a little video and you will see what I mean. I am using a small screw driver to emulate the Smot lifting the arms and unless the smot ramp was curved in my mind it is not going to play ball.
http://www.overunity.org.uk/smotg.htm
I tried a few different magnet configs with the ramp and the arms travelled a couple of inches turning the wheel but again getting the height was the problem.
I even used a big smot as below.
All good fun though and will pop the magnets back on the arms and mess around when I get more time.
Got to crack on with other projects for now.
Sean.
hartiberlin
Sean,
movie is not found under this link,
please update the link.
Many thanks.
