Magnet Motor Without Repelling Forces
Started by lmzxc, March 23, 2010, 11:56:04 PM
lmzxc
A magnet motor that does not use repelling forces;  there are three circles of gears.  Circle 3 gears have 140 teeth, and the other gears have 70 teeth.  Because of this arrangement, moving magnets are in power positions in relation to stationary metal rings all the way around the circle.  Green dot = magnet attached to gear 2 inches above gear; purple dot = magnet attached to gear 6 inches above gear; green circle = two-inch-wide steel ring 2 inches above gear; purple circle = two-inch-wide steel ring 6 inches above gear.  Motor is started and stopped by turning the two-inch-wide steel rings attached to supports attached to nuts that are on one-inch thread rod attached to up side of center gear holder.
The next model will have 2-inch thread rod beneath the rotating arms, and gear holders will be pointing down so that the two-inch-wide steel rings can be controlled from beneath, and the top of the motor will be used for a gear or pulley for transferring rotational force to an electrical generator.
lmzxc
The design in the picture above did not work.  I received a 140-tooth gear today and tested it on the prototype, and it did not keep what would be the magnets moving parrallel to what would be the rings.  The circular rings need to be replaced by curved pieces of metal slanting in and out along the paths of the two magnets attached to the 140-tooth gear (see picture below).  I hope to have a working prototype within 10 days.  lmzxc
Low-Q
My 2 cents:
Members if overunity.com will still ask for a working device for 3 month to a year after the 10 days have expired, and you will probably never show up with a working model ;D Anyways, that is the standard procedure for everyone that claims they have found a way to make a working magnet motor.
Remember you allways take into account that it might be a counterforce in the motor that fights back - most probably by an unexpected counter torque of some sort.
After being a member of overunity.com for a while, I have learned by mistake many times, spent too much time in motor that never turned up to be a working one, ideas that only see what it wants to see etc. etc. There have been many "what if" questions, but every time there has been something that due to the nature of forces, gravity or whatever, has forced the ideas into the trash can. One cannot trick nature that easy ;)
Br. and have a happy Easter holiday
Vidar
lmzxc
I have modified the design for the prototype; am in the process of getting more gears.  lmzxc
lmzxc
I have modified the design for the prototype a second time; am in the process of getting more gears.  lmzxc
