6 volts DC in 130 volts AC out simple generator
Started by magnetman12003, April 01, 2010, 04:41:06 PM
magnetman12003
IceStorm
Quote from: magnetman12003 on April 01, 2010, 04:41:06 PM
The below link shows and tells all.
http://www.youtube.com/watch?v=fO9GhHvWGJA
Tom
lol , alot to learn in electronic, take your time, you will finally understand the basic of the basic. :) . Begin with Ohm law and after that delete your video.
Bruce_TPU
Tom
Hi Tom,
I have been following your work on youtube, very nicely done!
I would suggest, taking some very fast diodes and building a rectifier for the output, rectify it to dc, put it across a resistor and take a current measurment.  I am very curious to see where it stands...  If it is not OU, it in no way diminishes your work, you just keep being creative as you have been and push the envelope...
Cheers,
Bruce
Low-Q
http://www.a.com/watch?v=fO9GhHvWGJA
Tom
It actually it doesent tell a thing. Volt isn't energy itself. It's in theory no problem in generating several gigavolts out of a 1.5VAAA battery. The question is how much current it can carry. The output product of "current x voltage" cannot exceed the input product of "current x voltage".
That means that you will have a current drop as the voltage raises. And visa versa.
Vidar
magnetman12003
[A author=Bruce_TPU link=topic=8990.msg235870#msg235870 date=1270192648]
Hi Tom,
Cheers,
Bruce
[/quote] Hi Bruce,
Hi Bruce,
Thanks for your comment.  I will take your advice and do just that. I bought a true RMS multimeter and am waiting for its arrival.   I always did wonder what kind of power output a spinning magnet under a load would have when spun by low DC  voltage and current.  I am having fun never the less.
