GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
magnetman12003
Quote from: Rapadura link=topic=9076.msg238934#msg238934 A=1272199831
@magnetman12003: Are you going to use a rectifier to have DC output in this experiment?
I will figure out both AC and rectified DC Power.
DeepCut
I tidied up the circuit by improving the contacts and mounting in a project box, my first one it's great fun !
Also changed height of coil, it wasn't dead-centre vertically before.
Also using 100k resistor rather than pot as a load.
System components :
Drive circuit: Bedini, no JonnyDavro relay. Using 10k, 3-contact linear pot.
Drive coil : Bifilar, single coil.
               Trigger wire : 0.25mm.
               Induction wire : 0.28mm.
Magnet : Neo @ 6,100 gauss.
Full wave bridge rectifier, shop-bought, maximum reverse-current is 10A per diode.
Load resistor : 100k
Resistance of Bedini pot : ~1200
Peak performance result :
Input : 9.43 VDC @ 0.075 A = 0.70725 W
Output (rectified) : 41.5 VDC @ 0.035 A = 1.4525 W
Apparent COP = 2.053729232944503 ...
I ran the test 10 times and all results were similar, these are average figures.
*EDIT* What's an easy way of switching between the PSU and the rectified output ? Can i just connect the output to where the input goes to begin with or will that blow my house up lol ? *EDIT*
Bruce_TPU
Quote from: DeepCut on May 05, 2010, 07:00:53 PM
System components :
Try using a DPDT (double pole double throw) switch.  When you throw the dpdt, the psu turns off and the output becomes the input.  If it keeps running, time and film it.  Put the set up on a glass table, or or glass top of some type when filming.
Good Luck!
Cheers,
Bruce
DeepCut
e2matrix
Nice work there Deepcut.  If you want to really get a fast switchover on the input (from the output) I'd suggest a double pole double throw relay if you happen to have one around.  It would normally get it done faster than a switch (depending somewhat on the switch).  On the other hand if your motor tends to keep up the RPM fairly well for a couple seconds after being switched off then it may not make any difference using a relay over a regular DPDT switch.  Of course having a disconnect somewhere in the setup would be advised just in case it does starting going faster thus producing more power and looping into higher speed etc. to self destruct mode.   We can all hope you see that problem at least  ;D  so just have a way to unplug or turn off if you get lucky.
