What about this video?
Started by Rapadura, April 30, 2010, 09:25:24 PM
Rapadura
Look at this:
http://www.youtube.com/watch?v=M9cDtpbjvTc
Is there any thread here at Overunity.com about this video?
I'm trying to understand why he didn't build a closed loop system with that...
Rapadura
As you can see, the rotor magnet passes along the stator magnet, and is not attracted back to the stator magnet, it simply stops at an angle from the stator magnet that is greater than the angle of the initial position.
[ EDIT ]
In fact, I don't know if there is a rotor magnet. That thing on the rotor maybe don't be a magnet, but just an piece of iron or other metal.
[ /EDIT ]
onthecuttingedge2005
Quote from: Rapadura on April 30, 2010, 09:25:24 PM
Look at this:
Clanzer is a good guy but you are wasting your precious time on something that doesn't work.
Rapadura
How could this not work??? The rotor passes through the sticky spot and is not attracted back!!
gravityblock
Quote from: Rapadura on April 30, 2010, 10:05:45 PM
@Rapadura:  Don't give up on this idea.  I think this can be made to work.
It looks like ClanZer is using another stator magnet to break the attraction force of the rotor magnet after it runs past the first stator, which is similar to what I've been working on.  His method is more elegant and less complicated than mine.
I really don't see why this technique can't work with the proper alignment and precession.  I actually lost my breath earlier when one of my rotors made one complete turn under it's own power before coming to a stop (the other rotor didn't make it).  I don't think my bottom and top rotor magnets are far enough away from each other.  I'm currently using 2 parallel rotors with 3 magnets on each rotor along with 1 stator for each rotor (one stator for the bottom rotor and another stator for the top rotor).  The bottom stator will break the attraction force of the top rotor while the top stator will break the attraction force of the bottom rotor.
GB
