SM's TPU SUMMARY. What We Know So Far.
Started by FatBird, May 02, 2010, 08:11:57 PM
FatBird
Scientists & Inventors here on OverUnity have been working on the TPU for over 3 years now.  I thought it would help if we SUMMARIZED what we know at this point in 2010.
1.  All of SM’s TPUs have an AIR CORE, with NO Ferrite or Iron.
     SOURCE:  See Figures 2 & 3.
2.  Remember, when SM cut the 17 inch TPU apart in a video, witnesses said it was a CORK LIKE material.  That cork like TPU material was a SHIPPING Platform for heavy 17 inch Speakers.  Remember he worked in a Sound, Video, & Speaker store.
3.  SM’s TPUs use Stranded Copper Wire.  He also mentioned regular Lamp Cord Wire.
     SOURCE:  SM’s writings, see below.
4.  Since his TPUs overheat after 20 to 30 minutes, that INFERS HIGH CURRENT in the Control Coils.  Speculation is that the Control Coil(s) are a CLOSED LOOP which would cause High Current.  Let’s face it, a 9 V sine or square wave fed into an Open Loop Control Coil would NOT cause over heating.
5.  SM’s TPUs have an inherent VIBRATION, NOISE, & GYROSCOPIC ACTION when running.
     SOURCE:  SM said so in the First 5 Minutes in Video 1 below.
6.  NONE of the TPUs have circular, concentric windings.
     SOURCE:  Figures 2 & 3.
7.  The 8 inch TPU PROVES that OverUnity is Possible with a MINIMUM of ONLY 2 WIRES (Probably Lamp Cord or Speaker Wire).
     SOURCE:  Figure 2.
8.  Figure 1 has a SMALL HUMP on top.  Common Sense dictates that hump houses a 9 V Battery and a single frequency Gen. That IMPLIES a VERY SIMPLE DESIGN.
     SOURCE:  Figure 1, & Paragraph 2 below.
9.  What about where SM said TPUs need 3 Frequencies with complex Control Coils? SM was referring to some of his EARLY PROTOTYPE units.  The simplicity in Figures 1 & 2 DISPROVE any alleged 3 frequency requirement.
VIDEO 1:
http://video.google.com/videoplay?docid=-1944827568401901581&q=overunity&hl=en#docid=167210479374903373
Fig 1 =  6 incher.
Fig 2 =  8 incher
Fig 3 =  17 incher
Fig 4 =  Plastic Speaker Unit.
MISC IMPORTANT POINTS FROM SM’s WRITINGS:
1.  Compass will spin up when turned on.
2.  Never tune too close to the exact frequency.
3.  Make a Kill Switch with Over Voltage & Heat Sensors.
4.  The Collector is a separate coil of multi strand copper wire.
5.  The frequency is directly related to the circumference of the collector coil.
6.  You could describe the useable current output of my TPU as DC but with some hash in it.
7.  The “TPU” units heat up to a potentially dangerous level after about 20 to 30 minutes.
PARAGRAPH 1:
Roland Schinzinger,  Dept. of Electrical and Computer Engineering (UCI) said:
The second unit was again toroid shaped with a large hole in the center. It was approximately 17” at the outside and 15” inside with a core thickness of approximately 1”.  The unit was 4” tall. The unit was not measured in weight but could be easily lifted with one hand, (ObS).
When the TPUs are unloaded the voltage climbs substantially and I do not mean a spike. It lasts for several seconds and is a good third higher. Steven calls it the turbine effect.
I asked the inventor if this was the limit of the unit and he replied, “no way.” He provided a quick blow fuse rated at 50 amperes.  With two large electrical clamps and wiring, he shorted the fuse across the output terminals of the toroid and destroyed the fuse, (ObS). There was only a slight flickering of the ten incandescent bulbs as observed although there was a tremendous discharge of sparks from the output terminals of the toroid unit.
The inventor then gave me the fuse for examination. It was warm to the touch and smelled acrid, (ObS). It was a large 240 volt AC air conditioner disconnect fuse and designed for severe service duty, (OsS).
The inventor’s claim that the large toroid output terminals were at lethal potential was no longer in question. The time was 11:20 AM when the inventor removed the small toroid unit from operation because of heat build up. I examined the small toroid unit and it was indeed quite hot to the touch.
PARAGRAPH 2:
Dear L-------,
I hope this letter finds you well and in good spirits.  I am sorry that you have not gotten enough sleep.  I have a great deal of trouble sleeping, myself.  I can’t get comfortable at all.  Everything hurts now!  I have been thinking about all of your questions regarding your endeavors of late.  It is obvious that you are putting out a lot of effort for this.  I commend you for your fortitude and tenacity.  You have the secrets and given enough time you will succeed.  I spent years perfecting the A.  Now I look back on it and say how stupid I was, and HOW EASY IT REALLY IS.  I think it is easy because I know exactly how to do it now!  For you it is not so.  You don't even have the simplest clues to head you in the right direction mechanically.  Please understand that I have given my word to others that I will not tell you how this process is done.  It is not that I would not like to tell you, because I would.  It is because I am a man of my word, and I gave my word I would not.  I gave my word to my Keepers (the company that pays me) and I gave my word to the federal government.
L-------, there is a wealth of knowledge in almost everyone of my letters.  You seem to be the only one who has the ability to absorb and digest the information the way it is intended.  After rereading my letters to you I became aware that in fact I have already sent you enough information to duplicate my power units.  I have certainly given you more to go on then I had when developing it.
PARAGRAPH 3:
In the beginning, we spent months and months trying in every conceivable way to duplicate a unit. The only thing that kept us going night and day was the fact that we already had one. We knew it was possible to have a working device. It was the only thing that kept us going on the project. And even then we said I GIVE UP so many times I can’t count. Think of the output as dc (pulsed) 5 KHz with lots of Hash in it.
On to another point. There is an inertia effect. You can actually create a revolving field with inertial! That is what I have referred to as , The inertia effect.  There is a genuine gyroscopic effect when the units are on. Everybody has noticed that when held and in operation, the units have a definite vibration and have a gyroscopic effect..  They seam to resist being moved through the air. When placed on a smooth surface it is very pronounced. Some of you should think about that. I hope the things I share with you give you ideas about how my unit works. As you know, I am a great believer in understanding, not copying. If anyone ever gets one of these things operating, have them measure the electro-magnetic and hash radio around the unit....it will blow your mind. so, what does that do to control devices in close proximity?
Sincerely,
SM.
PARAGRAPH 4:
Some of the units in the demo videos did in fact have one or two 9V batteries to provide a separate controllable DC source for the solid state control circuit.  We eventually learned how to make the power converters start with only the flick of a permanent magnet across the coils.  You may find it humorous that we had to find a way to make the things work without any batteries purely because UEC needed us to honestly answer the question â€" “Does it have any batteries inside of it”?  They wanted us to be able to truthfully answer NO, to anyone who asked that question.  You would be surprised how difficult it can be to explained to a lay person how impossible it is to convert a 9V battery into the juice needed to light a single 100 watt 120 volt light bulb, let alone make toast with an electric toaster!!!
PARAGRAPH 5:
By the way, we found that ordinary multi strand lamp cable worked very well for use as a collector.  Thick gauge wire can dissipate the heat very well but there are two problems.  First the heavy gage wire isn't as efficient as the multi strand copper and also there is a safety advantage in using the multi strand lamp cable.  If the unit goes too far on frequency it may begin to convert too much current and try to dissipate way too much voltage.  The multi strand wire will just burn up and open the circuit whereas the heavy gauge wire will continue to conduct until there will be the equivalent of a lightning strike of the unit.  That of course ends the operation of the unit but can also prove to be rather dramatic and also somewhat dangerous if you are in close proximity to the power unit.
WEIGHTS & MEASUREMENTS RELATED TO SM’s TPUs:
12 Ounce Open Unit in the 38 Min Film.
OD = 6 inches.
Height = 2 inches.
Thickness = 1 inch.
Output = 186V @ 5 Amps
.7 Amps with a Heat Sink.
Small 1 Pounder, Open Coil.  Took Magnet from his pocket.
OD = 4 inches.
Height = 1 3/4 inches.
Output = 100V @ 1 Amp.  7.3 Hz & 5 KHz.
5 Inch Unit evaluated at U of C, by Dr Schinzinger
Date:  12-12-95
OD = 4 ¾”.    ID = 3 ”
Thickness = 7/8 ”
Height = 2”
Weight = He said Very Light.
Output = 137 V at 1 Amp through a 100 W Bulb.
Luminescence Meter Measured = 2.5
15 Inch Unit evaluated at U of C, by Dr Schinzinger
Date:  12-12-95
OD = 15”.    ID = 13 ”
Thickness = 1 ”
Height = 4”
Weight = He said about 6 pounds.
Output = 614 V
Small Open Coil, 1 1/2  Pounder:
OD = 6 inches.
Height = 2 inches.
Thickness = 3/4 inches.
Output = 120V @ 5 Amps.  7.3 Hz & 5 KHz.
Large 17" Open Coil.
OD = 17 inches.
Height = 4 inches.
Thickness =
Weight = 6 Pounds.
Output = 830V @ 10 Amps
innovation_station
i read the first line .. and i question the info provided .. as sm plainly says .. he USED BALING WIRE...
sheesh
he did not say HEY  here is my air core coil ...  lol
that apears to be iron to me ...
ist
FatBird
Two YEARS AGO, GK said that BAILING WIRE was a GENERIC TERM, refering to cobbling something together.
It is like the man that said he is holding his old car or tractor together with Bailing Wire.
otto
Hello all,
@FatBird
your post....hmmmm.......the weights .......air cores???
OK. Just 1 question if you dont mind: the open TPU where we see 2 round black frames connected together, to say so and some lamp wires, whats the weight of this unit??
Sorry, Im a little bit older and my brain is a little bit on a "lower level" and my eyes too.
Otto
FatBird
Hi Otto,
WELCOME SIR.  Good to see you around & about today.
I have never heard a weight given for that 8 incher in any of the videos.
It looks fairly light, so my wild guess is about a pound & a half.
Have a good day.
