Thanks to ALL for your help!!
made this with phun - free energy?
Started by FreeEnergy, May 10, 2010, 03:49:54 PM
FreeEnergy
have a small motor spin a weight attached to a lever and this causes leverage work to a load (a bigger motor?).
in this simulation the spring is a "load".
would the load have sufficient energy to feed the small motor? would this machine self run?
i have attached the phun file to this post inside a zip file, enjoy.
DeepCut
Hey thanks FreeEnergy, i'd never heard of Phun before it's great !
Gary.
Rapadura
Phun is fun!
I liked the simulation, but the problem is that we can't measure the energy spent by the motor...
Rapadura
This simulation raises one more time the question: is it possible to use a lever to "leverage" energy?
Is there a way to do this?
infringer
my take on a lever after going through the whole lever thing with the sword of god and Archer...
I believe no matter what you do the same amount of work a lever works like a pulley or gear on your bike....
You still do the same amount of work it just makes the work easier lets say to compress a spring it takes 1 inch but a 5lbs of force with your bare hands you use a lever to compress the same spring it takes only 1lb of force well I will be damned but guess what you are no longer going 1" to do this instead you are moving 5" with 1lb of force was there really any net gain?
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
