Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
hartiberlin
Hi Bill,
better first try to scale the weight and the magnets and the coils
up, so you can light constantly a 1 Watts LED  non flickering...
Then I am happy to rewind manually the clock each day twice and
use this to charge up a battery.Maybe you can modify the spring in the
clock for more power output ?
Just try to show how much INSTANT always usable power you can generate at maximum
with it...
This would be great.
Many thanks.
hartiberlin
Bill checkout this magnet coil magnet
combination.
http://www.freelights.co.uk/how.html
you could use this easily with several coils along the swinging
path and generate a lot of energy without breaking the motion
of the pendulum.
it might even give the pendulum some additional mechanical pushes...
billmehess
I did try something very similar to this at one time. The "drag force" as they call it is sufficint enough to stop the pendulum.
Here is what I am going to do.
I will charge up with my system 100 ea to one volt 1000uf caps. I will then dump that to a 1f 50 volt cap.
repeatley until I have 25 volts in the large 1f cap, at that point I can generate around 8 seconds of "wind time".
I have tried this with some smaller 1f 5.5 volt caps I have with a smaller motor and it works really well.
If this works then I have the first REAL overunity self closed loop system.
This 1f 50 volt cap is quite large in size and not readly available but I have found a source and will order it in Fri. morning.
Dingus Mungus
If the system requires 12 seconds of wattage to rewind, then storing 8 seconds of wattage means the system is only 66% efficent. Sorry but thats the deal, and that means 8 seconds would not be overunity.  :-\
billmehess
No No No,you don't understand. I can produce that 8 seconds of "wind time"in around 4 days. Remember I have 28 days to work with.
In 28 days I can produce much more than what I need to keep the device running continously.
Also even if I chose to rewind the clock for 8 second intervals  this would in itself run the device for 66% of 28 days or around 17 days.I have pleanty of power!!
