How to build a gravity wheel.
Started by AB Hammer, June 11, 2010, 01:26:12 PM
DreamThinkBuild
Hi Smoky,
Ya, something like that.
I tried a hammer with a hole at the end mounted to a shaft(no magnets). It did swing pretty good(starting from the 12 o'clock position) but not very far into quadrant 4(just on the edge). It would seem that the magnetic ramp might have to extend half way into quadrant 3. It could be the weight was off or too much friction in my rough test.
Another idea is to mount the hammer to one side of a bicycle wheel for using better bearings.
Low-Q
Just have in mind that a SMOT ramp does not add extra energy. It is just permanent magnets that will not provide any extra energy at all - really!
Vidar
AB Hammer
Because nobody has posted it. I will post it here for construction reason for ideas.
http://peswiki.com/index.php/OS:_F._M._Chalkalis_Gravity_Wheel
Yes he is using a motor to accelerate the overbalanced wheel. Will it ever make enough energy to power itself? This would be for opinions and testing.
I wanted to point out his holding device for wheel builds. I found it to be simple and effective.
I only had a short time, and I'm back to the shop.
Alan
Alan
mscoffman
Quote from: AB Hammer on July 09, 2010, 08:27:41 PM
In a perfect world the supports for something will be perfectly
stiff, but in the real world. Even the stiffest support with have
small movement excursions associated with them. This means
the universe provides a back energy wave associated with the
forward energy wave created by the gravitational imbalance
from the machine. Only if the support were perfect would there
be no energy exchange. So I think a material's physical stiffness
is a source of this energy, annealed or recharged to some
extent by random thermal motion. and fracture and breakage is
an indication that this material energy has been discharged.
You can see this is happening where his nailed wood headboard
is beginning to separate apart.
Capturing only a small amount of back energy wave in a high
efficiency device would be needed, but does one call this
overunity energy or does one call it stored energy? The
self annealing part probably truly is overunity.
:S:MarkSCoffman
sm0ky2
Alan
That video is interesting for a couple of reasons.
what i see in this video is a tiny motor hes using the turn the two upper "roller-drive" wheels.
This is a well known propulsion technology. It is used in everything from toy HotWheel car racetracks, to bumpercars, even Skybuckets, Skilifts, baseball throwing machines, Skeet Shot launchers,balistic-testing machines, the list goes on and on. Basicaly the full momentum of the high-speed rollers is transfered to the object and the process is very efficient. - the fact that he used this particular method, over a million other choices, tells me hes got something going on upstairs. not yur average backyard tinkerer.
This type of expertise ( i believe) can only come from a long time of working on the problem, as many of us know all too well.
This guy ( at least from my first impression) appears to be honestly working towards the cause. As opposed to thousands of people that hoax an effect and act stupid about how it could ever have happened.... or try to get $$ out of fools, for their phony balogny device that does nothing at all.
he has the engineering right, hes done his math...
we should give him a thread and get him over here...
anyways,.
The second thing that stands out,
is the fact that he is adding the propulsion force:
A) not only at the top of the stroke (bingo!),
but also
B)on the same plane as the gravitational vector. (double bingo!) -
which i think is useful knowledge, should a particular gravity-wheel include the addition/re-integration of rotational force.
